Drop box, evernote etc
- Drop box, evernote etc
01-08-2014 5:09 PM
Is there a program similar to Dropbox or Evernote that will allow me to transfer files between a computer and tablet using Linux Mint..
I am thinking about jpeg and pdf files. Or is it not possible to do this.
Having tried both of the above I get a message to say they are not available in linux.
We are born into history and history is born into us.
4 REPLIES 4
Re: Drop box, evernote etc
01-08-2014 5:12 PM
If it's an Android tablet then try Airdroid https://play.google.com/store/apps/details?id=com.sand.airdroid&hl=en_GB . The only thing it needs on the host is a browser. I use it with both Windows and Linux ( Firefox ).
01-08-2014 5:18 PM
Thank you, I will check that out
01-08-2014 5:28 PM
Dropbox works on both Android & Linux Mint, I know I use it all the time.
Just checked
Dropbox installer for Linux 32 & 64 bit versions
Just checked
01-08-2014 5:34 PM
Yes, I use DropBox on Ubuntu. The advantage of Airdroid is that it'll do the transfer locally via wifi, it also does Contacts etc
