Draytek Vigor 2865 / Draytek 167 on WAN2
ClarityNDT
Morning everyone, - Hi Strat!
I had this working, and now it isn't. Go figure.
Details: Business customer / static IP
VDSL is on another ISP and is working fine, WAN2 is set up through a vigor 167 bridge in "dumb" mode, so PPPOE is set up through the 2865.
At some point, for some unknown reason this has been disabled. So, enabled it but no connection.
Currently have the following settings:
PPPOE: enabled
Service name (optional:) Plusnet
Username: 'username'@plusdsl.net
password: password
Index(1-15) in schedule setup: blank
Wan connection details
Mode: PPP Detect
MTU: 1492
TTL: enable
PPP/MP Setup
PPP Authentication: PAP/CHAP/MS-CHAP/MS-CHAPv2
Idle Timeout -1 (seconds)
Fixed IP: YES advised.ip.address.
MAC Address: Default
Static or Dynamic IP tab
Disabled
PPTP/L2TP tab
IPV6 tab
connection type: offline
The vigor 167 is showing an active dsl line, so I'm working on this being a configuration issue
Any clues?
TIA
Chris.
5 REPLIES 5
Fixes: 579
Re: Draytek Vigor 2865 / Draytek 167 on WAN2
You need to set the Fixed IP to No and Enable the Dynamic IP.
Even if you have a static IP with Plusnet, it still is allocated dynamically by PN, its just that you always get the same one!
ClarityNDT
I had an feeling this was the case so have tried both ways. Same result - no connection.
Now set to dynamic.
Fixes: 579
Mode: PPP Detect
Not sure about that , should it be 'always on' perhaps ?
Does the Draytek log give any clues ?
Is this an existing config ? Is it ADSL or VDSL ?
bobpullen
Fixes: 330
Early afternoon yesterday, there were a raft of failed connection attempts due to a rejected password, so I suspect that's where at least one of the problems lies.
ClarityNDT
That'll do it.
tyvm.
