Disc Cleanup W7
Mav
Fixes: 515
Disc Cleanup W7
I began to run out of space on my 60GB SSD (down less than 1GB free) so set about manually deleting some files but only got it up to just over 3GB.
I then ran Disc Cleanup where over 5GB of Windows Update files were found. The box was ticked so I clicked OK to delete them but the free space remains at 3GB.
There's nothing in the Recycle Bin and running Disc Cleanup again shows just 2MB of Windows Update files left.
So, why isn't the deleted 5GB now showing as free space?
Any ideas?
Forum Moderator and Customer
8 REPLIES 8
Scribe
Re: Disc Cleanup W7
It's at the back of my mind that I've noticed something like that, and it doesn't show up until after a restart - not SSD though!
Mav
Fixes: 515
Re: Disc Cleanup W7
Sheer coincidence but we had a power outage soon after posting.
On reboot it showed a message that Windows was updating and once to desktop there the files were ... gone  Smiley
TORPC
Re: Disc Cleanup W7
Do you keep the device on 24 / 7
If so
I always recommend, completing a reboot before applying any major changes
Mav
Fixes: 515
Re: Disc Cleanup W7
Yes, it's on 24/7.
I don't remember there being any updates this week, though.
TORPC
Re: Disc Cleanup W7
Them sneaky little critters are everywhere Wink
Don't tell me Window Definition was amongst then ?Huh
Also use Ccleaner / if you haven't already Wink
ejs
Aspiring Hero
Fixes: 25
Re: Disc Cleanup W7
It was the windows update cleanup that triggered the boot time messages about configuring updates.
gleneagles
Aspiring Legend
Fixes: 17
Re: Disc Cleanup W7
Not sure of what make of SSD's you have  but Samsung magician is a handy tool to have.
We are born into history and history is born into us.
demonix01
Re: Disc Cleanup W7
I would suggest that you clear out all the old system restore points with the exception of the latest one (you should be able to do this from the disc cleanup when you are in the more advanced section) if you have it active as that will get you a few gigs of space back.
