win8.1 update
- win8.1 update
win8.1 update
28-07-2014 7:02 PM
http://www.nextpowerup.com/news/10980/microsoft-starts-working-on-windows-8-1-update-3.html
Re: win8.1 update
29-07-2014 9:43 PM
Re: win8.1 update
29-07-2014 10:56 PM
Re: win8.1 update
29-07-2014 11:01 PM
Re: win8.1 update
30-07-2014 8:51 AM
Something similar here, and I thought THAT was expensive (but needed it for business).
Quote from: petecov44 I got my copy of 8 for £24,99 from MS
Why anyone would pay £99 to upgrade an old PC to Windows 8 I struggle to comprehend.
Re: win8.1 update
30-07-2014 11:19 AM
it was for me.. I was back on Win 7 after a week. Last time I tried to use win8 it said my key was invalid so in the end of no value/use at all ;(
:edit: It was £14,99 actually I just found the receipt with the Key on it
Re: win8.1 update
30-07-2014 11:24 AM
Re: win8.1 update
30-07-2014 8:16 PM
Quote from: HPsauce Why anyone would pay £99 to upgrade an old PC to Windows 8 I struggle to comprehend.
I have had several clients who had machines running XP who yielded to the campaign mounted by Microsoft to frighten them into upgrading. They weren't crazy, just ill-informed. The result generally hasn't been too bad with the fresh copy of Windows 8 typically out-performing the old copy of Windows XP. I've only done these upgrades on computers bought at the very end of the XP era.
Re: win8.1 update
30-07-2014 8:54 PM
The one I have "upgraded" is an mid-era Vista system and it works fine, as did several older XP systems that I tested it on, though they have all now been scrapped.
Quote from: ReedRichards ...Windows 8 typically out-performing the old copy of Windows XP. I've only done these upgrades on computers bought at the very end of the XP era.
Performance wise it's not at all bad, but at £99 it is bad value in my (hopeful well-informed) eyes. Even worse if on top of that you paid someone to do the "upgrade" which is of course a clean install from XP. £25 that I paid was OK as I did all the work myself, used a Vista system that was being scrapped and the XP system it replaced was literally on its last legs.
Re: win8.1 update
30-07-2014 9:25 PM
Quote from: HPsauce ..... Even worse if on top of that you paid someone to do the "upgrade" which is of course a clean install from XP.
Yes - except that they paid me to do the upgrade!
I free-up or create a second partition, install 8.1 to that, discuss the pros and cons of a Microsoft Account, check Device Manager for unidentified hardware, install the printer (which usually requires drivers from the manufacturer's web site), add the obvious utilities, copy the user files from the XP partition and usually return a few weeks later to erase the old XP partition when the client is confident everything has been transferred.
Re: win8.1 update
30-07-2014 10:19 PM
Business is business, as they say.
Quote from: ReedRichards Yes - except that they paid me to do the upgrade!
