Dead monitor, repair or replace
- Re: Dead monitor, repair or replace
27-10-2009 3:01 PM
Quote from: Santiago So I am waiting with baited breath to see what happens.
Should that be "bated breath"?
27-10-2009 3:44 PM
28-10-2009 7:49 AM
28-10-2009 8:47 AM
29-10-2009 1:13 PM
Quote from: ReedRichards What happened about the monitor? I get the impression that LCD monitors may not be too difficult to repair if you know what you are doing but there aren't many people around who do know how to do it.
Actually they seem pretty easy to repair because for some reason lot of them share the same weak point - capacitors. You'd be amazed how many of those pesky things start leaking and cause devices to die a premature death. They're also cheap as chips to obtain (though granted a little hard to find) and easy peasy to replace too. Admittedly you do need some soldering equipment but thats easy enough to obtain.
29-10-2009 2:12 PM
01-11-2009 9:03 PM
01-11-2009 10:54 PM
Looks like I will have to chase him tomorrow
02-11-2009 4:17 PM
(oops..... if your monitor is bust , ......... you won`t be able to view them......! )
02-11-2009 8:55 PM
(Still no estimate yet, but I didn't have time to call him today)
03-11-2009 3:27 PM
Quote from: shutter YouTube....(oops..... if your monitor is bust , ......... you won`t be able to view them......! )
maybe where the instructions on finding the golden rivet is to be found there too !!
07-11-2009 12:31 PM
http://www.berr.gov.uk/whatwedo/consumers/fact-sheets/page38311.html
07-11-2009 12:41 PM
07-11-2009 1:07 PM
I had some luck with Tesco recently.
http://www.robdickson.co.uk/blog/2009/11/01/new_trainers_from_tesco_part_two
07-11-2009 1:50 PM
As you say those extended warranties are worthless.
However, it is very doubtful that a 3 year old monitor (an electronic item) would be deemed to be faulty when sold.
