DNS Server Not Responding
Boz
I'm been having a lot of problems recently with Internet Access.   On running the diagnostic program, the message "DNS Server not responding" appears.   My question is in two parts:   what is the function of the DNS server; and what causes it not to respond?
Boz
16 REPLIES 16
Re: DNS Server Not Responding
Hi @Boz, the purpose  of a DNS server is to translate the name of a domain i.e. bbc.co.uk in to an IP address e.g. 123.123.123.111. This IP address is then used to make the physical connection from your PC to the site in question.
When DNS server doesn’t respond it may be because it’s too busy, offline or broken. You may want to change your DNS to 1.1.1.1 to see if this changes what you are experiencing.
Boz
Hi Mook
Thanks for the reply.
Where is the DNS Server?   And how do I change its setting?
Boz
That would depend on what router you have @Boz so without knowing that you could try this on your own PC as it will effect only your PC so will help decide if you need to change it at the router so it applies to all connected devices.
https://developers.google.com/speed/public-dns/docs/using (Windows 7, Mac and Linux)
https://www.windowscentral.com/how-change-your-pcs-dns-settings-windows-10 (Windows 10)
Boz
Many thanks for the links, Mook.
I noticed in the preamble the comment "if the DNS servers provided by your ISP aren't reliable...".   This seems to suggest that it is a Plusnet problem and that Plusnet provide these servers, wherever they are !!.   Should I be discussing this with the Plusnet Tech guys?
Boz
Some users do find that the PN DNS Server's don't always work they way they should and what I'm telling you now would be the same as others would*. But I'm suggesting you change the PC DNS first to help eliminate the fact that the Plusnet ones may be causing you issues.
* Well maybe that's not 100% correct some user's would tell you to change them in the router and be done, but that's treating the symptom, not the cause.
VileReynard
Fixes: 20
Look at your DNS server IP numbers in your router, make a note of them and from a command screen,
ping 123.456.789.999
(or whatever your DNS addresses are, for each address).
If it is sluggish then change one or both of your DNS addresses to 1.0.0.1 or 8.8.4.4 (non-Plusnet DNS servers)
If you have Linux you can use the dig command to test actual DNS lookup times for a site using a variety of different servers.
Boz
Hi VileReynard
Many thanks for the suggestion.   By the way, why is there an alternative DNS server address?   Is it common for the primary address to fail?
Boz
When new sites are added, moved or deleted not every DNS server knows as the changes take some time to propagate around the world, so having secondary or even tertiary DNS addresses allows for these occasions as you have more chance of resolving a new address. And of course they can act as a backup when one of them fails or is too busy to respond.
ejs
Aspiring Hero
Fixes: 25
@Anonymous
That is not at all what the secondary DNS address is for. The only purpose of the secondary address is for when you don't receive a reply from the primary. If you receive an old address or a it doesn't exist response from the primary, then that's the answer you take.
@ejs - Oh I stand corrected in my orthopaedic slippers. Thumbs_Up
VileReynard
Fixes: 20
I thought it was so that a client (the PC) could issue requests to both DNS servers and take the first response?
For example:-
ejs
Aspiring Hero
Fixes: 25
I don't think it's supposed to be done like that, as that just seems like a waste of resources. I use the "strict-order" configuration with dnsmasq, but it can be configured differently.
VileReynard
Fixes: 20
Very interesting - I'll look into it.
Boz
Hi Guys
If I change the DNS server addresses on the PC, would I also have to make a similar change to those on the router?
Boz
