DLNA Server not showing on Mac
- DLNA Server not showing on Mac
Re: DLNA Server not showing on Mac
01-05-2017 3:15 PM
Not to sure what the point of your post is @Browni, I know it works, as I've said already, and I have now had it working on Windows R2 2012, 7, 8, 10 and iPad so the issue is with the Mac. But from doing some searching I'm not the only one, so that's reassuring.
01-05-2017 3:29 PM
01-05-2017 3:34 PM
01-05-2017 3:34 PM
Yes, up to your post the only Windows version was R2 2012 and also VLC on the iPad, which is why I knew the server was working as it should. I did the other tests on Windows just to double check.
01-05-2017 3:36 PM
02-05-2017 2:49 AM
Any chance you could try a different Mac OSX? (On another drive perhaps)
02-05-2017 7:34 AM
The share or rather the NAS does appear in Finder and when selected the shares appear as you can see below. But this has nothing to do with DLNA as that is a service so doesn’t need the shares to be mounted on the host.
Mac’s don’t have any native DLNA support built in hence the need to use apps like VLC to play content. But you may be right in pointing the finger at the OS but as to the root cause, well I don’t know and as I can’t check other versions I am reliant on others to help with that.
I assume @RPMozley from your comment that you don’t have a DLNA server on your network? As if you did then a check using your OS would have been very helpful.
02-05-2017 6:28 PM
02-05-2017 9:14 PM
Thanks @RPMozley, I guess that wouldn't matter provided the application used was the 2.2.4 version of VLC just to see if it works on your version of OSX.
12-05-2017 6:42 PM
Note taken on VLC version.
16-05-2017 8:08 PM
Right-clicking the section shows Disable, so must be enabled then. If yours is saying Enable then it's disabled somehow.
Advice is to either use a different app (Kodi does ok) or if you still want to use VLC, maybe try trashing (binning) the VLC preference files and start afresh.
16-05-2017 9:16 PM - edited 16-05-2017 9:18 PM
Why bother with DLNA/UPnP? Just use SMB/CIFS...
17-05-2017 6:39 AM
Thanks for taking the time to do this @RPMozley, but I'm confused. You say the Kodi UPnP share appears taking time to populate with a reference to LVC 2.2.4. But then you say the latest VLC shows nothing. Can you provide a screen capture of what you have please.
17-05-2017 6:40 AM
Because it defeats the purpose of having a DLNA Server.
17-05-2017 1:11 PM
