Connect Smart TV to the Internet
ReedRichards
Seasoned Pro
Fixes: 25
Re: Connect Smart TV to the Internet
The fact that you have no DNS set is more than a clue, it's a reason, probably the reason, your internet connection does not actually work.  Normally it would get set to the same IP address as the router, if done automatically.  However the Google DNS servers would work equally well or possibly better.
@feilim, from reading the last few posts it would appear that this is indeed the problem. As you have followed @Anoush’s advice you also need to add the DNS server addresses as given by @Mustrum. Once you have added these addresses I think you’ll find that the TV will now connect to the internet in the way you expect.
However this doesn’t explain why when using DHCP it doesn’t work. As pointed out by others here the information you added manually should be assigned automatically when the connection is set to DHCP. It should really be plug and play.
Fixes: 581
We've seen on here in the past that some Panasonic TV's didn't work with DHCP and had to have IP's set manually. Maybe Sony are using some of the same software ?
feilim
I don't know. All settings been done correct with IP etc but not connecting to App Store etc
DS
Seasoned Champion
Fixes: 22
The only thing I can suggest is to click on the following link - <Click me> - note the numbers given there under Primary DNS and Secondary DNS, type this in and see if they work.....
I really can't see what's missing from the other contributions, unless your TV doesn't like Google's DNS for any odd reason.
My only other thought is to change the IP address suggested by Anoush on the previous page to something like 192.168.1.200
Do any other apps work, iPlayer for example?
edit to tidy up the click me link
feilim
All fixed 😊. Done a factory reset on tv and when setting up tv it asked for wifi password and that was everything working. I can now access all apps etc again. Sometimes turning everything off and on again works the best lol. Thanks to everyone who helped me. I hope this topic helps someone in the future.
Anoush
Aspiring Hero
Fixes: 139
Yay. Thanks for letting us know.
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
DS
Seasoned Champion
Fixes: 22
ditto
At times, a factory reset and start again is all it needs Wink
If you do have issues in the future, it will probably wifi related, so either pop back here or connect it via ethernet (and leave it connected like that if you can)
ashley1001
Hi, this worked for me as well. I did a factory reset on my Sony Smart TV and then connected to the One Hub router using the WPS option on the TV.
Woody123
Wireless is better anyway wired for may TVs is restricted to 100mbps
Fixes: 249
100mbps is way more than is required by a single and in most settings is more than Wi-Fi will do.  Even if faster, you do not want to be saturating your Wi-Fi capacity by the heavy demand of just one device.
RealAleMadrid
Fixes: 68
@Townman It is somewhat strange that the OP has registered on the forum today to post on a thread that was marked as fixed over 8 years ago.🤔
@Woody123 in almost all cases for fixed devices a wired ethernet connection is the best option. WiFi is convenient for mobile devices if the speed is acceptable and the connection is reliable.
Woody123
Fair point, but just compared with a 4k YouTube video, got average 80mbps with lan and 103mbps on Wi-Fi.
To be fair I couldn’t notice any difference though.
