Connecing to usenet from abroad
theoule
Is there a way to connect to plusnets news server when I am abroad.?
I've tried logging in with my username and password, but I get an error with access denied.
Fixes: 167
Re: Connecing to usenet from abroad
Unfortunately you can't use a client to access our Usenet feed when on a different network, however you can access it via the portal if you log in (although the interface leaves a lot to be desired).
 Chris Parr
 Plusnet Staff
Fixes: 10
Quote from: Chris
... and frequently makes you unpopular with other users as it doesn't link posts properly.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
theoule
Quote from: Chris
That sure is a clunky interface.  Oh well, google groups will have to do.
Thanks anyway.
