ISPA testing 2011 - Questions for Plusnet
daveplus
I have registered for the testing but as part of the installation, I specified a low limit to testing downloads. What limit does Plusnet expect testers to specify? Or, is it no limit?
Also, I won't leave my PC running 24/7 so what is the minimum required on-time?
Dave
RyanCouldwell
Re: ISPA testing 2011 - Questions for Plusnet
You can still take part  with a lower data limit; however the higher data limit you set, the more information you will provide for the test.
With regards to how long you have to be online, there is no specified minimum. However once again the longer you are online, the more information you will provide for the test.
Cheers,
Ryan
daveplus
Thanks Ryan
Dave
