Cisco 887VA or 897VA Router setup on Plusnet FTTC guide
TurboApples
Re: Cisco 887VA or 897VA Router setup on Plusnet FTTC guide
Was just typing this as it notified me you had replied - I managed to get my working - I had somehow missed off the ip route command. Roll_eyes
However, I needed to make some changes to the NAT configuration from your original guide as it just would not work for me with those settings. Also, in the original guide I believe there is an error with the dhcp config, the default-router should be 192.168.1.254.
Below is my config incase it helps anyone else and thanks for doing the orignial guide in the first place!
hostname PlusNetRouter
ip source-route
ip cef
no ipv6 cef
vtp mode transparent
controller VDSL 0
interface Ethernet0
 no ip address
interface Ethernet0.101
 description Tagging for PPPoE (VDSL 0)
 encapsulation dot1Q 101
 no ip redirects
 no ip proxy-arp
 ip virtual-reassembly in
 pppoe-client dial-pool-number 1
interface ATM0
 no ip address
 shutdown
 no atm ilmi-keepalive
interface FastEthernet0
 switchport access vlan 10
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface Vlan1
 no ip address
 ip nat inside
interface Vlan10
 description locals
 ip address 192.168.1.254 255.255.255.0
 ip nat inside
interface Dialer0
 mtu 1492
 ip address negotiated
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat outside
 encapsulation ppp
 ip tcp adjust-mss 1452
 dialer pool 1
 dialer-group 1
 ppp authentication pap chap ms-chap callin
 ppp chap hostname [email protected]
 ppp chap password 0 Password
 ppp ipcp address accept
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dhcp excluded-address 192.168.1.254
ip dhcp pool LAN
 network 192.168.1.0 255.255.255.0
 dns-server 8.8.8.8 8.8.4.4
 default-router 192.168.1.254
ip nat inside source list 1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 1 permit 192.168.1.0 0.0.0.255
witherford
Was just typing this as it notified me you had replied - I managed to get my working - I had somehow missed off the ip route command. Roll eyes
That was my first guess in my response Roll_eyes
witherford
HI did you have any chance to try my suggestions?
Hi, Sorry I haven't got a chance so far to test it again, I was setting up my server cabinet and getting everything working with that, also a new wireless network.
I'll hopefully try and get back at it tonight, I've talked with one of my lecturer's and he thinks it might be NAT that isn't configured correctly, though I'm using your config and it seems like that's fine?
My lecturer pointed something out than your config for the 887 had a NAT pool, he said it looked like it was pointing to another router or a modem.
TurboApples
Maybe you need to make the same changes I did. Dont use a NAT pool command, make sure the default-router in DHCP points to 192.168.1.254 and that Dialer0 is used in the NAT settings rather than Ethernet0.101
Basically replace DHCP and NAT settings with this: (use whatever DNS servers you want)
ip dhcp pool LAN
witherford
I do need to correct some errors with my NAT but i cannot amend the post unfortunately.
Well, I was kind of sick of having to try to set this up and pulling my hair out so I bought a Cisco RV130W and it took literally less than 10 seconds to set up and have a working connection.
steveknowles
Hey TurboApples
With regards to missing the route off,
if you have the command below on the dialer interface, it will install the route given durning ppp negotiation.
int dialer x
ppp ipcp route default
Steve
Aydnit
Has anyone else had issues with getting the line to sync up I have a flashing CD light and the vdsl interface keeps transitioning from handshake to idle... What version of modem firmware are you guys using?
Fixes: 480
@Aydnit
Duplicating topics causes confusion, see https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Issues-with-887VA-config/m-p/1858254#M...
Aydnit
@Baldrick1, yes apologies for adding to the confusion, I created a separate thread but wasn't sure how to remove this one
Fixes: 480
@Aydnit
For info you only have a short window to edit posts after which they are locked.
