Old modem and new modem suffering frequent disconnects.
CageUK
Hi, for sometime and increasing frequency my broadband service drops off completely, I have a high bandwidth cable from filter to modem and the desktop is connected via ethernet, I have requested the line test and was reported no errors while the modem log clearly shows the disconnections, I purchased an Asus DSL N16 modem router and have experience the exact same behavior and it even warns me of an unstable line, below is as much of the log as I can fit in, can anyone identify a problem or suggest a solution please?
2022-03-01 15:25:09 [Informational] WAN Connection: WAN was restored.
2022-03-01 15:25:09 [Informational] start_nat_rules: apply the nat_rules(/tmp/nat_rules)!
2022-03-01 15:25:10 [Informational] kernel:
2022-03-01 15:25:10 [Informational] kernel: #### wan_primary: [146.90.217.103]
2022-03-01 15:25:10 [Informational] kernel: ddns_execute(), DDNS is not enable, so remove /etc/ddns.conf.
2022-03-01 15:25:16 [Debug] kernel: nas0: no IPv6 routers present
2022-03-01 15:25:35 [Warning] syslog: IPV6CP: timeout sending Config-Requests
2022-03-01 15:28:46 [Informational] kernel: Link State: DSL link down.
2022-03-01 15:28:46 [Informational] kernel: Link State: PVC_0 PPPoE down.
2022-03-01 15:28:46 [Informational] WAN Connection: Wan link down.
2022-03-01 15:28:46 [Informational] stop_nat_rules: apply the redirect_rules!
2022-03-01 15:29:36 [Informational] kernel: Link State: DSL link up.
2022-03-01 15:29:37 [Informational] WAN Connection: Wan link up.
2022-03-01 15:29:37 [Informational] syslog: Terminating on signal 15
2022-03-01 15:29:37 [Informational] syslog: Connect time 4.6 minutes.
2022-03-01 15:29:37 [Informational] syslog: Sent 54802 bytes, received 74170 bytes.
2022-03-01 15:29:37 [Informational] syslog: LCP down.
2022-03-01 15:29:39 [Informational] kernel: tc3162_atm_close done
2022-03-01 15:29:39 [Informational] kernel: ==> check_mulif_interface_existnas0
2022-03-01 15:29:39 [Informational] kernel: ==> to find mulif group of device nas0
2022-03-01 15:29:39 [Informational] kernel: ==>mulif err, no find mulif group of device nas0
2022-03-01 15:29:40 [Informational] RFC1483/2684 bridge: Interface "nas0" created sucessfully
2022-03-01 15:29:40 [Informational] RFC1483/2684 bridge: Communicating over ATM 0.0.38, encapsulation: LLC
2022-03-01 15:29:40 [Informational] kernel: mt7510_config
2022-03-01 15:29:40 [Informational] kernel: mt7510_atm_open
2022-03-01 15:29:40 [Informational] kernel: vpi: 0
2022-03-01 15:29:40 [Informational] kernel: vci: 38
2022-03-01 15:29:40 [Informational] kernel: mt7510_atm_open vc 0:
2022-03-01 15:29:40 [Informational] kernel: ATM over ADSL mode init
2022-03-01 15:29:40 [Informational] kernel: dslUpRate: 2517
2022-03-01 15:29:40 [Informational] RFC1483/2684 bridge: Interface configured
2022-03-01 15:29:40 [Informational] RFC1483/2684 bridge: RFC 1483/2684 bridge daemon started
2022-03-01 15:29:40 [Informational] kernel: enter br2684_init_hook function
2022-03-01 15:29:40 [Informational] kernel: mt7510_init_MPOA
2022-03-01 15:29:40 [Informational] kernel: Init VC 0 MPOA Function
2022-03-01 15:29:40 [Informational] kernel: MPOA Mode: MODE_BRIDGE
2022-03-01 15:29:40 [Informational] kernel: MuxType: MUX_LLC
2022-03-01 15:29:40 [Informational] kernel: Mode: MODE_BRIDGE
2022-03-01 15:29:40 [Informational] kernel: br2684_init_hook: success
2022-03-01 15:29:41 [Informational] syslog: Initialize LCP.
2022-03-01 15:29:43 [Informational] syslog: Plugin libpppoe.so loaded.
2022-03-01 15:29:43 [Informational] syslog: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.7
2022-03-01 15:29:43 [Notice] syslog: pppd 2.4.7 started by admin, uid 0
2022-03-01 15:29:43 [Informational] syslog: LCP is allowed to come up.
2022-03-01 15:29:43 [Debug] syslog: PADS: Service-Name: ''
2022-03-01 15:29:43 [Informational] syslog: PPP session is 6888
2022-03-01 15:29:43 [Warning] syslog: Connected to 0c:a4:02:dc:1a:9d via interface nas0
2022-03-01 15:29:43 [Debug] syslog: using channel 503
2022-03-01 15:29:43 [Informational] syslog: Using interface ppp0
2022-03-01 15:29:43 [Notice] syslog: Connect: ppp0 <--> nas0
2022-03-01 15:29:43 [Informational] syslog: CHAP authentication succeeded: CHAP authentication success
2022-03-01 15:29:43 [Informational] dnsmasq[10996]: reading /etc/resolv.conf
2022-03-01 15:29:43 [Informational] dnsmasq[10996]: using nameserver 212.159.6.10#53
2022-03-01 15:29:43 [Informational] dnsmasq[10996]: using nameserver 212.159.6.9#53
2022-03-01 15:29:43 [Warning] dnsmasq[10996]: ignoring nameserver 127.0.0.1 - local interface
2022-03-01 15:29:43 [Informational] dnsmasq[10996]: exiting on receipt of SIGTERM
2022-03-01 15:29:43 [Informational] kernel: Link State: PVC_0 logistic interface up.
2022-03-01 15:29:43 [Informational] dnsmasq[17668]: started, version 2.78 cachesize 150
2022-03-01 15:29:43 [Debug] dnsmasq[17668]: compile time options: no-IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC no-ID no-loop-detect no-inotify
2022-03-01 15:29:44 [Informational] dnsmasq[17668]: using nameserver 212.159.6.9#53
2022-03-01 15:29:44 [Informational] dnsmasq[17668]: using nameserver 212.159.6.10#53
2022-03-01 15:29:44 [Informational] dnsmasq[17668]: reading /etc/resolv.conf
2022-03-01 15:29:44 [Warning] dnsmasq[17668]: ignoring nameserver 127.0.0.1 - local interface
2022-03-01 15:29:44 [Error] dnsmasq[17668]: bad address at /etc/hosts line 2
2022-03-01 15:29:44 [Informational] dnsmasq[17668]: read /etc/hosts - 5 addresses
2022-03-01 15:29:44 [Informational] kernel:
2022-03-01 15:29:44 [Informational] kernel: [route_setting]remove interface[0]=[ppp0]
2022-03-01 15:29:44 [Informational] kernel: [qos_execute(9411)]:Force Turn Off Bandwidth Limiter on Guest Network.
2022-03-01 15:29:46 [Informational] kernel:
2022-03-01 15:29:46 [Informational] kernel: #### wan_primary: [146.90.217.103]
2022-03-01 15:29:46 [Informational] kernel: ddns_execute(), DDNS is not enable, so remove /etc/ddns.conf.
2022-03-01 15:29:47 [Informational] WAN Connection: WAN was restored.
2022-03-01 15:29:47 [Informational] start_nat_rules: apply the nat_rules(/tmp/nat_rules)!
2022-03-01 15:29:52 [Debug] kernel: nas0: no IPv6 routers present
2022-03-01 15:30:12 [Warning] syslog: IPV6CP: timeout sending Config-Requests
2022-03-01 15:30:35 [Informational] kernel: Link State: DSL link down.
2022-03-01 15:30:35 [Informational] kernel: Link State: PVC_0 PPPoE down.
2022-03-01 15:30:38 [Informational] WAN Connection: Wan link down.
2022-03-01 15:30:38 [Informational] stop_nat_rules: apply the redirect_rules!
2022-03-01 15:31:23 [Informational] kernel: Link State: DSL link up.
2022-03-01 15:31:25 [Informational] WAN Connection: Wan link up.
2022-03-01 15:31:26 [Informational] syslog: Terminating on signal 15
2022-03-01 15:31:26 [Informational] syslog: Connect time 1.8 minutes.
2022-03-01 15:31:26 [Informational] syslog: Sent 50849 bytes, received 443497 bytes.
2022-03-01 15:31:26 [Informational] syslog: LCP down.
2022-03-01 15:31:26 [Notice] syslog: Connection terminated.
2022-03-01 15:31:28 [Informational] kernel: tc3162_atm_close done
2022-03-01 15:31:28 [Informational] kernel: ==> check_mulif_interface_existnas0
2022-03-01 15:31:28 [Informational] kernel: ==> to find mulif group of device nas0
2022-03-01 15:31:28 [Informational] kernel: ==>mulif err, no find mulif group of device nas0
2022-03-01 15:31:29 [Informational] RFC1483/2684 bridge: Interface "nas0" created sucessfully
2022-03-01 15:31:29 [Informational] RFC1483/2684 bridge: Communicating over ATM 0.0.38, encapsulation: LLC
2022-03-01 15:31:29 [Informational] kernel: mt7510_config
2022-03-01 15:31:29 [Informational] kernel: mt7510_atm_open
2022-03-01 15:31:29 [Informational] kernel: vpi: 0
2022-03-01 15:31:29 [Informational] kernel: vci: 38
2022-03-01 15:31:29 [Informational] kernel: mt7510_atm_open vc 0:
2022-03-01 15:31:29 [Informational] kernel: ATM over ADSL mode init
2022-03-01 15:31:29 [Informational] kernel: dslUpRate: 2159
2022-03-01 15:31:29 [Informational] kernel: enter br2684_init_hook function
2022-03-01 15:31:29 [Informational] kernel: mt7510_init_MPOA
2022-03-01 15:31:29 [Informational] kernel: Init VC 0 MPOA Function
2022-03-01 15:31:29 [Informational] kernel: MPOA Mode: MODE_BRIDGE
2022-03-01 15:31:29 [Informational] kernel: MuxType: MUX_LLC
2022-03-01 15:31:29 [Informational] kernel: Mode: MODE_BRIDGE
2022-03-01 15:31:29 [Informational] kernel: br2684_init_hook: success
2022-03-01 15:31:29 [Informational] RFC1483/2684 bridge: Interface configured
2022-03-01 15:31:29 [Informational] RFC1483/2684 bridge: RFC 1483/2684 bridge daemon started
2022-03-01 15:31:30 [Informational] syslog: Initialize LCP.
2022-03-01 15:31:32 [Informational] syslog: Plugin libpppoe.so loaded.
2022-03-01 15:31:32 [Informational] syslog: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.7
2022-03-01 15:31:32 [Notice] syslog: pppd 2.4.7 started by admin, uid 0
2022-03-01 15:31:32 [Informational] syslog: LCP is allowed to come up.
2022-03-01 15:31:32 [Informational] WAN Connection: Fail to connect with some issues.
2022-03-01 15:31:41 [Debug] kernel: nas0: no IPv6 routers present
2022-03-01 15:31:45 [Debug] syslog: PADS: Service-Name: ''
2022-03-01 15:31:45 [Informational] syslog: PPP session is 6940
2022-03-01 15:31:45 [Warning] syslog: Connected to 0c:a4:02:dc:1a:9d via interface nas0
2022-03-01 15:31:45 [Debug] syslog: using channel 504
2022-03-01 15:31:45 [Informational] syslog: Using interface ppp0
2022-03-01 15:31:45 [Notice] syslog: Connect: ppp0 <--> nas0
2022-03-01 15:31:45 [Informational] syslog: CHAP authentication succeeded: CHAP authentication success
2022-03-01 15:31:45 [Informational] syslog: CHAP authentication success
2022-03-01 15:31:45 [Notice] syslog: CHAP authentication succeeded
2022-03-01 15:31:45 [Notice] syslog: peer from calling number 0C:A4:02:DC:1A:9D authorized
2022-03-01 15:31:45 [Informational] dnsmasq[17668]: reading /etc/resolv.conf
2022-03-01 15:31:45 [Informational] dnsmasq[17668]: using nameserver 212.159.6.9#53
2022-03-01 15:31:45 [Informational] dnsmasq[17668]: using nameserver 212.159.6.10#53
2022-03-01 15:31:45 [Warning] dnsmasq[17668]: ignoring nameserver 127.0.0.1 - local interface
2022-03-01 15:31:45 [Notice] syslog: local IP address 146.90.217.103
2022-03-01 15:31:45 [Notice] syslog: remote IP address 172.16.18.131
2022-03-01 15:31:45 [Notice] syslog: primary DNS address 212.159.6.10
2022-03-01 15:31:45 [Notice] syslog: secondary DNS address 212.159.6.9
2022-03-01 15:31:46 [Informational] dnsmasq[17668]: exiting on receipt of SIGTERM
2022-03-01 15:31:46 [Informational] dnsmasq[20240]: started, version 2.78 cachesize 150
2022-03-01 15:31:46 [Debug] dnsmasq[20240]: compile time options: no-IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC no-ID no-loop-detect no-inotify
2022-03-01 15:31:46 [Informational] dnsmasq[20240]: using nameserver 212.159.6.9#53
2022-03-01 15:31:46 [Informational] dnsmasq[20240]: using nameserver 212.159.6.10#53
2022-03-01 15:31:46 [Informational] dnsmasq[20240]: reading /etc/resolv.conf
2022-03-01 15:31:46 [Warning] dnsmasq[20240]: ignoring nameserver 127.0.0.1 - local interface
2022-03-01 15:31:46 [Error] dnsmasq[20240]: bad address at /etc/hosts line 2
2022-03-01 15:31:46 [Informational] dnsmasq[20240]: read /etc/hosts - 5 addresses
2022-03-01 15:31:46 [Informational] kernel: Link State: PVC_0 logistic interface up.
2022-03-01 15:31:47 [Informational] kernel: [route_setting]remove interface[0]=[ppp0]
2022-03-01 15:31:47 [Informational] kernel: [qos_execute(9411)]:Force Turn Off Bandwidth Limiter on Guest Network.
2022-03-01 15:31:47 [Informational] WAN Connection: WAN was restored.
2022-03-01 15:31:47 [Informational] start_nat_rules: apply the nat_rules(/tmp/nat_rules)!
2022-03-01 15:31:52 [Informational] kernel:
2022-03-01 15:31:52 [Informational] kernel: #### wan_primary: [146.90.217.103]
2022-03-01 15:31:52 [Informational] kernel: ddns_execute(), DDNS is not enable, so remove /etc/ddns.conf.
2022-03-01 15:32:16 [Warning] syslog: IPV6CP: timeout sending Config-Requests
2022-03-01 15:35:10 [Informational] kernel: Link State: DSL link down.
2022-03-01 15:35:10 [Informational] kernel: Link State: PVC_0 PPPoE down.
2022-03-01 15:35:10 [Informational] WAN Connection: No response from ISP.
2022-03-01 15:35:10 [Informational] stop_nat_rules: apply the redirect_rules!
2022-03-01 15:35:18 [Informational] WAN Connection: Wan link down.
2022-03-01 15:36:00 [Informational] kernel: Link State: DSL link up.
2022-03-01 15:36:03 [Informational] WAN Connection: Wan link up.
2022-03-01 15:36:09 [Informational] syslog: Terminating on signal 15
2022-03-01 15:36:09 [Informational] syslog: Connect time 4.3 minutes.
2022-03-01 15:36:09 [Informational] syslog: Sent 30500 bytes, received 36101 bytes.
2022-03-01 15:36:09 [Informational] syslog: LCP down.
2022-03-01 15:36:09 [Notice] syslog: Connection terminated.
2022-03-01 15:36:09 [Informational] kernel: tc3162_atm_close done
2022-03-01 15:36:09 [Informational] kernel: ==> check_mulif_interface_existnas0
2022-03-01 15:36:09 [Informational] kernel: ==> to find mulif group of device nas0
2022-03-01 15:36:09 [Informational] kernel: ==>mulif err, no find mulif group of device nas0
2022-03-01 15:36:09 [Informational] dnsmasq[20240]: reading /etc/resolv.conf
2022-03-01 15:36:09 [Informational] dnsmasq[20240]: using nameserver 212.159.6.9#53
2022-03-01 15:36:09 [Informational] dnsmasq[20240]: using nameserver 212.159.6.10#53
2022-03-01 15:36:09 [Warning] dnsmasq[20240]: ignoring nameserver 127.0.0.1 - local interface
2022-03-01 15:36:09 [Informational] dnsmasq[20240]: exiting on receipt of SIGTERM
2022-03-01 15:36:09 [Informational] WAN Connection: WAN was restored.
2022-03-01 15:36:09 [Informational] start_nat_rules: apply the nat_rules(/tmp/nat_rules)!
2022-03-01 15:36:10 [Informational] kernel: Link State: PVC_0 logistic interface up.
2022-03-01 15:36:10 [Informational] dnsmasq[26409]: started, version 2.78 cachesize 150
2022-03-01 15:36:10 [Debug] dnsmasq[26409]: compile time options: no-IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC no-ID no-loop-detect no-inotify
2022-03-01 15:36:10 [Informational] dnsmasq[26409]: using nameserver 212.159.6.9#53
2022-03-01 15:36:10 [Informational] dnsmasq[26409]: using nameserver 212.159.6.10#53
2022-03-01 15:36:10 [Informational] dnsmasq[26409]: reading /etc/resolv.conf
2022-03-01 15:36:10 [Warning] dnsmasq[26409]: ignoring nameserver 127.0.0.1 - local interface
2022-03-01 15:36:10 [Error] dnsmasq[26409]: bad address at /etc/hosts line 2
2022-03-01 15:36:10 [Informational] dnsmasq[26409]: read /etc/hosts - 5 addresses
2022-03-01 15:36:11 [Informational] kernel: [route_setting]remove interface[0]=[ppp0]
2022-03-01 15:36:11 [Informational] kernel: [qos_execute(9411)]:Force Turn Off Bandwidth Limiter on Guest Network.
2022-03-01 15:36:12 [Informational] kernel:
2022-03-01 15:36:12 [Informational] kernel: #### wan_primary: [146.90.217.103]
2022-03-01 15:36:12 [Informational] kernel: ddns_execute(), DDNS is not enable, so remove /etc/ddns.conf.
2022-03-01 15:36:17 [Debug] kernel: nas0: no IPv6 routers present
2022-03-01 15:36:38 [Warning] syslog: IPV6CP: timeout sending Config-Requests
2011-01-01 00:00:42 [Informational] syslogd started: BusyBox v1.00 (2020.04.28-19:15+0000)
2011-01-01 00:00:42 [Informational] kernel: [route_setting]remove interface[0]=[ppp0]
2011-01-01 00:00:42 [Informational] WAN Connection: Wan link down.
2011-01-01 00:00:42 [Informational] kernel: Firmware version=[1.1.2.3]
2011-01-01 00:00:44 [Informational] stop_nat_rules: apply the redirect_rules!
2011-01-01 00:00:45 [Notice] crond[1928]: crond 2.3.2 dillon, started, log level 8
2011-01-01 00:00:45 [Informational] rstats[1939]: [start rstats]
2011-01-01 00:00:46 [Debug] kernel: add_ovpn_fw_rul used greatest stack depth: 12060 bytes left
2011-01-01 00:01:00 [Warning] syslog: Timeout waiting for PADO packets
2011-01-01 00:01:00 [Error] syslog: Unable to complete PPPoE Discovery
2011-01-01 00:01:00 [Informational] syslog: LCP down.
2011-01-01 00:01:04 [Informational] syslog: LCP is allowed to come up.
2011-01-01 00:01:10 [Informational] kernel: Link State: DSL link up.
2011-01-01 00:01:13 [Informational] kernel: tc3162_atm_close done
2011-01-01 00:01:13 [Informational] kernel: ==> check_mulif_interface_existnas0
2011-01-01 00:01:13 [Informational] kernel: ==> to find mulif group of device nas0
2011-01-01 00:01:13 [Informational] kernel: ==>mulif err, no find mulif group of device nas0
2011-01-01 00:01:14 [Informational] kernel: mt7510_config
2011-01-01 00:01:14 [Informational] RFC1483/2684 bridge: Interface "nas0" created sucessfully
2011-01-01 00:01:14 [Informational] RFC1483/2684 bridge: Communicating over ATM 0.0.38, encapsulation: LLC
2011-01-01 00:01:14 [Informational] kernel: mt7510_atm_open
2011-01-01 00:01:14 [Informational] kernel: vpi: 0
2011-01-01 00:01:14 [Informational] kernel: vci: 38
2011-01-01 00:01:14 [Informational] kernel: mt7510_atm_open vc 0:
2011-01-01 00:01:14 [Informational] kernel: ATM over ADSL mode init
2011-01-01 00:01:14 [Informational] kernel: dslUpRate: 2253
2011-01-01 00:01:14 [Informational] kernel: enter br2684_init_hook function
2011-01-01 00:01:14 [Informational] kernel: mt7510_init_MPOA
2011-01-01 00:01:14 [Informational] kernel: Init VC 0 MPOA Function
2011-01-01 00:01:14 [Informational] kernel: MPOA Mode: MODE_BRIDGE
2011-01-01 00:01:14 [Informational] kernel: MuxType: MUX_LLC
2011-01-01 00:01:14 [Informational] kernel: Mode: MODE_BRIDGE
2011-01-01 00:01:14 [Informational] kernel: br2684_init_hook: success
2011-01-01 00:01:14 [Informational] RFC1483/2684 bridge: Interface configured
2011-01-01 00:01:14 [Informational] RFC1483/2684 bridge: RFC 1483/2684 bridge daemon started
2011-01-01 00:01:15 [Informational] WAN Connection: Fail to connect with some issues.
2011-01-01 00:01:15 [Informational] syslog: Initialize LCP.
2011-01-01 00:01:15 [Informational] syslog: Plugin libpppoe.so loaded.
2011-01-01 00:01:15 [Informational] syslog: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.7
2011-01-01 00:01:15 [Notice] syslog: pppd 2.4.7 started by admin, uid 0
2011-01-01 00:01:15 [Informational] syslog: LCP is allowed to come up.
2011-01-01 00:01:20 [Debug] syslog: PADS: Service-Name: ''
2011-01-01 00:01:20 [Informational] syslog: PPP session is 7216
2011-01-01 00:01:20 [Warning] syslog: Connected to 0c:a4:02:dc:1a:9d via interface nas0
2011-01-01 00:01:20 [Debug] syslog: using channel 1
2011-01-01 00:01:20 [Informational] syslog: Using interface ppp0
2011-01-01 00:01:20 [Notice] syslog: Connect: ppp0 <--> nas0
2011-01-01 00:01:21 [Informational] syslog: CHAP authentication succeeded: CHAP authentication success
2011-01-01 00:01:21 [Informational] syslog: CHAP authentication success
2011-01-01 00:01:21 [Notice] syslog: CHAP authentication succeeded
2011-01-01 00:01:21 [Notice] syslog: peer from calling number 0C:A4:02:DC:1A:9D authorized
2011-01-01 00:01:21 [Notice] syslog: local IP address 146.90.217.103
2011-01-01 00:01:21 [Notice] syslog: remote IP address 172.16.18.131
2011-01-01 00:01:21 [Notice] syslog: primary DNS address 212.159.6.9
2011-01-01 00:01:21 [Notice] syslog: secondary DNS address 212.159.6.10
2011-01-01 00:01:21 [Informational] dnsmasq[2503]: started, version 2.78 cachesize 150
2011-01-01 00:01:21 [Debug] dnsmasq[2503]: compile time options: no-IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC no-ID no-loop-detect no-inotify
2011-01-01 00:01:21 [Informational] dnsmasq[2503]: using nameserver 212.159.6.10#53
2011-01-01 00:01:21 [Informational] dnsmasq[2503]: using nameserver 212.159.6.9#53
2011-01-01 00:01:21 [Informational] dnsmasq[2503]: reading /etc/resolv.conf
2011-01-01 00:01:21 [Warning] dnsmasq[2503]: ignoring nameserver 127.0.0.1 - local interface
2011-01-01 00:01:21 [Error] dnsmasq[2503]: bad address at /etc/hosts line 2
2011-01-01 00:01:21 [Informational] dnsmasq[2503]: read /etc/hosts - 5 addresses
2011-01-01 00:01:21 [Informational] kernel: [route_setting]remove interface[0]=[ppp0]
2011-01-01 00:01:22 [Informational] kernel: [qos_execute(9411)]:Force Turn Off Bandwidth Limiter on Guest Network.
2011-01-01 00:01:22 [Informational] kernel: Link State: PVC_0 logistic interface up.
2022-03-01 15:42:46 [Informational] kernel:
2022-03-01 15:42:46 [Informational] kernel: #### wan_primary: [146.90.217.103]
2022-03-01 15:42:46 [Informational] kernel: ddns_execute(), DDNS is not enable, so remove /etc/ddns.conf.
2022-03-01 15:42:48 [Informational] WAN Connection: WAN was restored.
2022-03-01 15:42:48 [Informational] start_nat_rules: apply the nat_rules(/tmp/nat_rules)!
2022-03-01 15:42:48 [Debug] kernel: nas0: no IPv6 routers present
2022-03-01 15:43:13 [Warning] syslog: IPV6CP: timeout sending Config-Requests
2022-03-01 15:43:24 [Warning] crond[1928]: time disparity of 5871822 minutes detected
2022-03-01 15:45:38 [Informational] kernel: WPS button is pressed!
2022-03-01 15:45:39 [Informational] kernel: WPS button is pressed!
2022-03-01 15:45:40 [Informational] kernel: WPS button is pressed!
2022-03-01 15:45:41 [Informational] kernel: WPS button is pressed!
2022-03-01 15:45:41 [Informational] kernel: wps_enable=[1]
2022-03-01 15:45:41 [Informational] kernel: ==>Set_ManualMultiClientOn_Proc()
2022-03-01 15:45:41 [Informational] kernel: <==Set_ManualMultiClientOn_Proc(ManualMultiClientOn = 1)
2022-03-01 15:45:41 [Informational] kernel: RTMPIoctlMAC():wrq->u.data.length=18, pointer(7ff954f0)=60200618=D7E87D10!
2022-03-01 15:45:41 [Informational] kernel: RTMPIoctlMAC():after trim space, ptr len=17, pointer(81157000)=60200618=D7E87D10!
2022-03-01 15:45:41 [Informational] kernel: ==>Set_Debug_Proc()
2022-03-01 15:45:41 [Informational] kernel: <==Set_Debug_Proc(RTDebugLevel = 0)
2022-03-01 15:45:41 [Informational] kernel: Detected and trigger WPS Btn.
2022-03-01 15:46:20 [Informational] kernel: Link State: DSL link down.
2022-03-01 15:46:20 [Informational] kernel: Link State: PVC_0 PPPoE down.
2022-03-01 15:46:21 [Informational] WAN Connection: No response from ISP.
2022-03-01 15:46:21 [Informational] stop_nat_rules: apply the redirect_rules!
2022-03-01 15:46:26 [Informational] WAN Connection: Wan link down.
2022-03-01 15:46:27 [Informational] WEB: User [admin] logged in from [192.168.1.5] via WEB
2022-03-01 15:47:10 [Informational] kernel: Link State: DSL link up.
2022-03-01 15:47:12 [Informational] WAN Connection: Wan link up.
2022-03-01 15:47:18 [Informational] syslog: Terminating on signal 15
2022-03-01 15:47:18 [Informational] syslog: Connect time 4.5 minutes.
2022-03-01 15:47:18 [Informational] syslog: Sent 46935 bytes, received 85152 bytes.
2022-03-01 15:47:18 [Informational] syslog: LCP down.
2022-03-01 15:47:18 [Informational] kernel: tc3162_atm_close done
2022-03-01 15:47:18 [Informational] kernel: ==> check_mulif_interface_existnas0
2022-03-01 15:47:18 [Informational] kernel: ==> to find mulif group of device nas0
2022-03-01 15:47:18 [Informational] kernel: ==>mulif err, no find mulif group of device nas0
2022-03-01 15:47:18 [Informational] RFC1483/2684 bridge: Interface "nas0" created sucessfully
2022-03-01 15:47:18 [Informational] RFC1483/2684 bridge: Communicating over ATM 0.0.38, encapsulation: LLC
2022-03-01 15:47:18 [Informational] dnsmasq[2503]: reading /etc/resolv.conf
2022-03-01 15:47:18 [Informational] dnsmasq[2503]: using nameserver 212.159.6.10#53
2022-03-01 15:47:18 [Informational] dnsmasq[2503]: using nameserver 212.159.6.9#53
2022-03-01 15:47:18 [Warning] dnsmasq[2503]: ignoring nameserver 127.0.0.1 - local interface
2022-03-01 15:47:18 [Informational] dnsmasq[2503]: exiting on receipt of SIGTERM
2022-03-01 15:47:18 [Informational] WAN Connection: WAN was restored.
2022-03-01 15:47:18 [Informational] start_nat_rules: apply the nat_rules(/tmp/nat_rules)!
2022-03-01 15:47:18 [Informational] kernel: Link State: PVC_0 logistic interface up.
2022-03-01 15:47:19 [Informational] dnsmasq[8591]: started, version 2.78 cachesize 150
2022-03-01 15:47:19 [Debug] dnsmasq[8591]: compile time options: no-IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC no-ID no-loop-detect no-inotify
2022-03-01 15:47:19 [Informational] dnsmasq[8591]: using nameserver 212.159.6.10#53
2022-03-01 15:47:19 [Informational] dnsmasq[8591]: using nameserver 212.159.6.9#53
2022-03-01 15:47:19 [Informational] dnsmasq[8591]: reading /etc/resolv.conf
2022-03-01 15:47:19 [Warning] dnsmasq[8591]: ignoring nameserver 127.0.0.1 - local interface
2022-03-01 15:47:19 [Error] dnsmasq[8591]: bad address at /etc/hosts line 2
2022-03-01 15:47:19 [Informational] dnsmasq[8591]: read /etc/hosts - 5 addresses
2022-03-01 15:47:20 [Informational] kernel: [route_setting]remove interface[0]=[ppp0]
2022-03-01 15:47:20 [Informational] kernel: [qos_execute(9411)]:Force Turn Off Bandwidth Limiter on Guest Network.
2022-03-01 15:47:22 [Informational] kernel:
2022-03-01 15:47:22 [Informational] kernel: #### wan_primary: [80.189.147.60]
2022-03-01 15:47:22 [Informational] kernel: ddns_execute(), DDNS is not enable, so remove /etc/ddns.conf.
2022-03-01 15:47:27 [Debug] kernel: nas0: no IPv6 routers present
2022-03-01 15:47:46 [Warning] syslog: IPV6CP: timeout sending Config-Requests
2022-03-01 15:50:58 [Informational] kernel: The test lab:255
2022-03-01 15:50:58 [Informational] kernel: log cicmd 0 (wan dmt2 set olr 3 )
2022-03-01 15:50:58 [Informational] kernel: US bitswap on,DS bitswap on
2022-03-01 15:50:58 [Informational] kernel: log cicmd 1 (wan dmt2 set olr 1 )
2022-03-01 15:50:58 [Informational] kernel: Set SNRM OFFSET = 2.0 db
2022-03-01 15:50:58 [Informational] kernel: log cicmd 2 (wan dmt2 set snrm -1024 -1024 )
2022-03-01 15:50:58 [Informational] kernel: Set Agc Vref1 = 65535 ; Vref2 = 65535 ; Vref3 = 65535
2022-03-01 15:50:58 [Informational] kernel: log cicmd 3 (wan dmt2 set vref 65535 65535 65535 65535 )
2022-03-01 15:50:58 [Informational] kernel: log cicmd 4 (wan dmt2 set updatesync default )
2022-03-01 15:50:58 [Informational] kernel: PROFILE30A_MULTI_MODE
2022-03-01 15:50:58 [Informational] kernel: G.inp mode
2022-03-01 15:50:58 [Informational] kernel: ANNEXAIJLM
2022-03-01 15:50:59 [Informational] kernel: Link State: DSL link down.
2022-03-01 15:50:59 [Informational] kernel: Link State: PVC_0 PPPoE down.
2022-03-01 15:51:01 [Informational] WAN Connection: Wan link down.
2022-03-01 15:51:01 [Informational] stop_nat_rules: apply the redirect_rules!
2022-03-01 15:51:11 [Informational] kernel: set cicmd 5
2022-03-01 15:51:11 [Informational] kernel: 1: wan dmt2 set olr 3
2022-03-01 15:51:11 [Informational] kernel: SRAON
2022-03-01 15:51:11 [Informational] kernel: 2: wan dmt2 set olr 1
2022-03-01 15:51:11 [Informational] kernel: OlrON
2022-03-01 15:51:11 [Informational] kernel: 3: wan dmt2 set snrm -1024 -1024
2022-03-01 15:51:11 [Informational] kernel: offset = -1024/512 / -1024/512 4: wan dmt2 set vref 65535 65535 65535 65535
2022-03-01 15:51:11 [Informational] kernel: AGC Vref1 = 65535 ; Vref2 = 65535 ; Vref3 = 65535 ; Vref4 = 65535
2022-03-01 15:51:11 [Informational] kernel: 5: wan dmt2 set updatesync default
2022-03-01 15:51:11 [Informational] kernel: Reset sync sym update to default value !!!
2022-03-01 15:51:48 [Informational] WAN Connection: Wan link up.
2022-03-01 15:51:48 [Informational] syslog: Terminating on signal 15
2022-03-01 15:51:48 [Informational] syslog: Connect time 4.6 minutes.
2022-03-01 15:51:48 [Informational] syslog: Sent 44550 bytes, received 64594 bytes.
2022-03-01 15:51:48 [Informational] syslog: LCP down.
2022-03-01 15:51:50 [Informational] kernel: tc3162_atm_close done
2022-03-01 15:51:50 [Informational] kernel: ==> check_mulif_interface_existnas0
2022-03-01 15:51:50 [Informational] kernel: ==> to find mulif group of device nas0
2022-03-01 15:51:50 [Informational] kernel: ==>mulif err, no find mulif group of device nas0
2022-03-01 15:51:52 [Informational] RFC1483/2684 bridge: Interface "nas0" created sucessfully
2022-03-01 15:51:54 [Informational] RFC1483/2684 bridge: Communicating over ATM 0.0.38, encapsulation: LLC
2022-03-01 15:51:54 [Informational] kernel: mt7510_config
2022-03-01 15:51:54 [Informational] kernel: mt7510_atm_open
2022-03-01 15:51:54 [Informational] kernel: vpi: 0
2022-03-01 15:51:54 [Informational] kernel: vci: 38
2022-03-01 15:51:54 [Informational] kernel: mt7510_atm_open vc 0:
2022-03-01 15:51:54 [Informational] kernel: ATM over ADSL mode init
2022-03-01 15:51:54 [Informational] kernel: dslUpRate: 2574
2022-03-01 15:51:54 [Informational] kernel: enter br2684_init_hook function
2022-03-01 15:51:54 [Informational] kernel: mt7510_init_MPOA
2022-03-01 15:51:54 [Informational] kernel: Init VC 0 MPOA Function
2022-03-01 15:51:54 [Informational] dnsmasq[8591]: reading /etc/resolv.conf
2022-03-01 15:51:54 [Informational] dnsmasq[8591]: using nameserver 212.159.6.10#53
2022-03-01 15:51:54 [Informational] dnsmasq[8591]: using nameserver 212.159.6.9#53
2022-03-01 15:51:54 [Warning] dnsmasq[8591]: ignoring nameserver 127.0.0.1 - local interface
2022-03-01 15:51:54 [Informational] kernel: Link State: DSL link up.
2022-03-01 15:51:54 [Informational] dnsmasq[8591]: exiting on receipt of SIGTERM
2022-03-01 15:51:54 [Informational] kernel: Link State: PVC_0 logistic interface up.
2022-03-01 15:51:55 [Informational] WAN Connection: WAN was restored.
2022-03-01 15:51:55 [Informational] start_nat_rules: apply the nat_rules(/tmp/nat_rules)!
2022-03-01 15:51:55 [Informational] dnsmasq[15361]: started, version 2.78 cachesize 150
2022-03-01 15:51:55 [Debug] dnsmasq[15361]: compile time options: no-IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC no-ID no-loop-detect no-inotify
2022-03-01 15:51:55 [Informational] dnsmasq[15361]: using nameserver 212.159.6.9#53
2022-03-01 15:51:55 [Informational] dnsmasq[15361]: using nameserver 212.159.6.10#53
2022-03-01 15:51:55 [Informational] dnsmasq[15361]: reading /etc/resolv.conf
2022-03-01 15:51:55 [Warning] dnsmasq[15361]: ignoring nameserver 127.0.0.1 - local interface
2022-03-01 15:51:55 [Error] dnsmasq[15361]: bad address at /etc/hosts line 2
2022-03-01 15:51:55 [Informational] dnsmasq[15361]: read /etc/hosts - 5 addresses
2022-03-01 15:51:56 [Informational] kernel: [route_setting]remove interface[0]=[ppp0]
2022-03-01 15:51:56 [Informational] kernel: [qos_execute(9411)]:Force Turn Off Bandwidth Limiter on Guest Network.
2022-03-01 15:51:57 [Informational] kernel:
2022-03-01 15:51:57 [Informational] kernel: #### wan_primary: [80.189.147.60]
2022-03-01 15:51:57 [Informational] kernel: ddns_execute(), DDNS is not enable, so remove /etc/ddns.conf.
2022-03-01 15:52:02 [Debug] kernel: nas0: no IPv6 routers present
2022-03-01 15:52:22 [Warning] syslog: IPV6CP: timeout sending Config-Requests
2022-03-01 16:09:49 [Debug] kernel: ifconfig used greatest stack depth: 12016 bytes left
2022-03-01 16:13:23 [Informational] kernel: AP SETKEYS WPA2 MAC=7C:A7:B0:9F:1E:D0
2022-03-01 16:17:18 [Informational] kernel: The test lab:255
2022-03-01 16:17:18 [Informational] kernel: log cicmd 0 (wan dmt2 set olr 3 )
Moderator's note by Dick (Strat): Post released from Auto Spam Filter.
1 REPLY 1
MJN
Fixes: 5
Re: Old modem and new modem suffering frequent disconnects.
You need to raise a fault and get it thoroughly investigated. You should also perform all your testing directly in the master socket and not via any filters, extension wiring etc. Narrow down the potential causes.
