Issues with 887VA config
Aydnit
  New to Plusnet and not had this problem with any other provider before. I am trying to replace Plusnet's HomeHub with an 887VA router which was working fine with my previous providers. I thought it would be a simple case of replacing the username and password but no such luck (Old ISP's and Plusnet were all FTTC service). Plusnet is the only ISP i seem to be having problems with.
Can anyone help me out here, has anyone had a similar problem? Maybe Modem Firmware need updating?
I believe the DSLAM will be the same as previous ISP's?
Details below:
No CD light on router. After configuring the username/password I get:
%VDSL_DAEMON-4-TRAINMODE_NOT_SUPPORTED: UNKNOWN transport mode is not supported on VDSL2.
I do see the VDSL interface constantly transition from handshake --->Idle
Modem details:
Firmware        Source          File Name
VDSL            embedded        VDSL_LINUX_DEV_01212008
Modem FW  Version:      130205_1433-4.02L.03.A2pv6C035j.d23j
Modem PHY Version:      A2pv6C035j.d23j
Config:
version 15.4
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname Internet
boot-start-marker
boot system flash c880data-universalk9-mz.157-3.M9.bin
boot-end-marker
aqm-register-fnf
no aaa new-model
ip cef
no ipv6 cef
multilink bundle-name authenticated
vpdn enable
vpdn-group 1
cts logging verbose
license udi pid C887VA-K9 sn XXXXXXXXX
username XXXXXX privilege 15 secret 5 XXXXXXXXX
controller VDSL 0
 operating mode vdsl2
 modem 0
 modem ukfeature
interface ATM0
 no ip address
 shutdown
 no atm ilmi-keepalive
interface Ethernet0
 no ip address
interface Ethernet0.101
 encapsulation dot1Q 101
 pppoe enable group global
 pppoe-client dial-pool-number 1
interface FastEthernet0
 switchport access vlan 17
 no ip address
 spanning-tree portfast
interface FastEthernet1
 switchport access vlan 10
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface Vlan1
 no ip address
interface Dialer1
 ip address negotiated
 no ip redirects
 ip nat outside
 ip virtual-reassembly in
 encapsulation ppp
 ip tcp adjust-mss 1432
 dialer pool 1
 dialer idle-timeout 0
 dialer persistent
 dialer-group 1
 ppp authentication pap chap ms-chap callin
 ppp chap hostname [email protected]
 ppp chap password 0 XXXXXXXXXXX
 ppp pap sent-username [email protected] password 0 XXXXXXXXXX
 ppp ipcp dns request
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 101 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip ssh version 2
control-plane
line con 0
 no modem enable
line aux 0
line vty 0 4
 login local
 transport input ssh
end
2 REPLIES 2
Fixes: 480
Re: Issues with 887VA config
@Aydnit
Have you been through this topic? https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Cisco-887VA-or-897VA-Router-setup-on-P...
Aydnit
@Baldrick1, thanks yes I went through that with a fine toothcomb. My wan config is almost identical I tried additional things like setting modem Options under the vdsl controller but no joy.
