Cannot access w3schools.com
Uniquely among websites, I cannot access pages at w3schools.com - pages come back with "ERR_CONNECTION_TIMED_OUT" (not just today - it's been happening for at least a couple of weeks). I can't even ping their numeric IP (66.29.212.110: confirmed using Google DNS) - it times out.
External site checkers say the site is OK, and I can access it via a Proxy (eg proxysite.com). But not otherwise.
Ideas?
12 REPLIES 12
Aspiring Hero
Fixes: 18
Re: Cannot access w3schools.com
Try www.w3schools.com
Crazy3
Hello and Welcome to the Forums. It may be of no help to you @JohnGeddes but I can access this site, I wonder what others are experiencing?
https://www.w3schools.com/
Same problem with www.w3schools.com, I'm afraid.
You can't ping it because it doesn't respond to pings.
Fixes: 51
The links work fine for me.
Seasoned Pro
Fixes: 4
Links work fine here too.
A float tip is pleasing in its appearance and even more pleasing in its disappearance.
Growing old is inevitable...But growing up is optional.
Works for me too.
I use http://downforeveryoneorjustme.com to check if a site is available to others.
"I use http://downforeveryoneorjustme.com to check if a site is available to others." - Yes, I had confirmed that the site was up before posting.
The multiple confirmations that other Plusnet users are OK reaching the site puts paid to my hypothesis of a Plusnet issue, and that prompted me (why didn't I think of this sooner?) to test from a different PC on the same network: that is OK too. So it is a machine-specific issue with reaching that site. If anyone has any suggestions of likely cause, that would be brilliant: meanwhile, thanks to all who tested for me.
Aspiring Hero
Fixes: 50
Hosts file?
Ex-Plusnetter now living life in the G,fast lane!
Aspiring Hero
Fixes: 18
fat finger?
Fixes: 4
The link works for me
Postscript - problem solved.
The cause was my subnet mask. I had moved away from 255.255.255.0 because I wanted to access devices in the ranges:
192.168.0.xxx ,
192.168.1.xxx and
192.168.2.xxx
My intention had been to set up for 192.168.anything - which needs a mask of 255.255.0.0
Instead, I had erroneously used 255.0.0.0 - meaning that my PC would consider any IP address beginning "192." to be local. And the IP address for w3schools begins with "192."
Thanks to those who offered suggestions.
