Cannot access w3schools.com
- Re: Cannot access w3schools.com
31-07-2017 12:30 PM
Uniquely among websites, I cannot access pages at w3schools.com - pages come back with "ERR_CONNECTION_TIMED_OUT" (not just today - it's been happening for at least a couple of weeks). I can't even ping their numeric IP (66.29.212.110: confirmed using Google DNS) - it times out.
External site checkers say the site is OK, and I can access it via a Proxy (eg proxysite.com). But not otherwise.
Ideas?
31-07-2017 12:38 PM
31-07-2017 12:39 PM
Hello and Welcome to the Forums. It may be of no help to you @JohnGeddes but I can access this site, I wonder what others are experiencing?
31-07-2017 12:48 PM - edited 31-07-2017 12:49 PM
Same problem with www.w3schools.com, I'm afraid.
31-07-2017 12:52 PM
You can't ping it because it doesn't respond to pings.
31-07-2017 12:52 PM
The links work fine for me.
31-07-2017 2:16 PM
Links work fine here too.
Growing old is inevitable...But growing up is optional.
31-07-2017 4:37 PM
Works for me too.
I use http://downforeveryoneorjustme.com to check if a site is available to others.
31-07-2017 5:02 PM
"I use http://downforeveryoneorjustme.com to check if a site is available to others." - Yes, I had confirmed that the site was up before posting.
The multiple confirmations that other Plusnet users are OK reaching the site puts paid to my hypothesis of a Plusnet issue, and that prompted me (why didn't I think of this sooner?) to test from a different PC on the same network: that is OK too. So it is a machine-specific issue with reaching that site. If anyone has any suggestions of likely cause, that would be brilliant: meanwhile, thanks to all who tested for me.
31-07-2017 5:03 PM
31-07-2017 8:27 PM
fat finger?
31-07-2017 8:31 PM
10-10-2017 2:27 PM
Postscript - problem solved.
The cause was my subnet mask. I had moved away from 255.255.255.0 because I wanted to access devices in the ranges:
192.168.0.xxx ,
192.168.1.xxx and
192.168.2.xxx
My intention had been to set up for 192.168.anything - which needs a mask of 255.255.0.0
Instead, I had erroneously used 255.0.0.0 - meaning that my PC would consider any IP address beginning "192." to be local. And the IP address for w3schools begins with "192."
Thanks to those who offered suggestions.
