Can't access news.plus.net
- Can't access news.plus.net
03-11-2014 3:01 PM
Since a few days ago I can no longer connect to news.plus.net using Thunderbird to read newsgroups.
I noticed a thread on this from a few days ago but I don't understan the solution the questioner had. My set-up has not changed at all for a year.
I have a Draytek Vigor 2860 broadband router and a Windows 7 PC, and a plusnet broadband connection.
I have not changed my Thunderbird settings, which are:
server: news.plus.net
port: 119
Connection security: none
"Always reques authentication..." is not checked
I raised a support ticket to plusnet but they replied "we've tested your connection and there is no problem, we suggest you use the community forum".
Well, I didn't say my connection was faulty - everything works fine apart from the error "Login to server news.plus.net failed" that Thunderbird gives when I try to read the news.
What has changed with the plusnet news server and why can't I connect to it?
thanks,
Michael
port: 119
thanks,
Michael
6 REPLIES 6
Re: Can't access news.plus.net
03-11-2014 7:10 PM
Hi Michael,
I've responded to your ticket regarding this.
03-11-2014 7:41 PM
I'm guessing that you have been allocated an IP address from a range newly acquired by Plusnet. Had you tried a simple disconnect/connect to see if a change of IP made a difference? You'd need to use something like http://www.whatsmyip.org/ to check that you'd been given one from a different range.
03-11-2014 7:57 PM
Hi Jelv,
That looks to be the issue in this scenario.
03-11-2014 8:10 PM
Very strange.
Not aware of my router having been switched off such that I might had a new IP address in the last week, but who knows. Anyway, seems to have solved it, thanks.
Michael
Michael
03-11-2014 9:32 PM
@Dan
Not sure why you hadn't posted to that effect on here as we'd know that was likely if anyone else reported the same issue and could advise them accordingly.
Has the tea boy been made aware so he can contact Giganews?
10-11-2014 12:15 PM
Hi jelv,
It's in hand and being looked at: http://community.plus.net/forum/index.php/topic,133596.msg1167871.html#msg1167871
