Blocking adult contents
bala
Hi
I tried everything to  block adult contents but no joy any one help me ?
7 REPLIES 7
Mav
Fixes: 518
Re: Blocking adult contents
Moderator's Note(s)
Thread moved from Fibre Broadband to Tech Help.
Forum Moderator and Customer
Fixes: 1,662
Hi there.
Are you trying to block the content via a broadband account or mobile service?
If broadband you'll be able to do this through Safeguard Here, but if this is regarding mobile feel free to PM me your account number and I'll be happy to arrange for content block to be added on.
bala
its my broadband connection , i tried everything tried to block porn but still no joy to block my side
Fixes: 480
 Plusnet Safeguard works by changing the router dns servers. Are you using your own router? If so this gives you the settings you need. https://www.plus.net/help/broadband/about-dns-server-and-website-settings/.
Can you log into your router and see what yours are set at?
bala
I am using plusnet router ,i blocked porn and restarted several times but no joy ...still works porn
Fixes: 480
 But you haven’t answered my question. For some reason Plusnet might not be able to access your router settings to update the dns addresses.
VileReynard
Fixes: 20
How are you accessing this porn?
Is it via adverts or web searches?
If the former, install an advert blocker.
I allow all content through - but I use an advert blocker and use a search engine that doesn't track my browsing.
Try to avoid Google searches.
