Bit Defender 2010.
- Bit Defender 2010.
Bit Defender 2010.
30-08-2009 9:23 PM
hi,
I have just installed bit defender antivirus 2010 and just wondering your views on this product,is it as good as the big names like eset nod 32,avg,avast, kaspersky?im finding it a treat to use,great interface with an option to use either novice,intermediate,or expert,fastish scans aprox 40 min for deep system scan,i removed windows defender as bit defender has real time protection and im not wanting to risk any conflicts,the antivirus cost me £15.00,cheap so will it do as good a job as the big names?im sure i will find out,one gripe i find so far is that it takes ages when working with google mail to view my mail etc,i might just have to start using my plusnet email account for e-mails,or it might just simply be a prob with goole mail just now
If life gives you lemons, make lemonade.
1 REPLY 1
Re: Bit Defender 2010.
30-08-2009 9:47 PM
For detection it is up with the big boys but may have more false positives.
Have a look at the reviews here http://www.av-comparatives.org/
Note these test were on 2009 not 2010
Have a read here http://www.wilderssecurity.com/showthread.php?t=251167
