BT Smart Hub 2 using and Firmware updates
cpe33
I am thinking of buying a BT Smart Hub 2 with Disk. Will it work on PlusNet and will the Smart Hub get Firmware updates?
4 REPLIES 4
LifeonMars
Seasoned Pro
Fixes: 12
Re: BT Smart Hub 2 using and Firmware updates
Yes and Yes
see Post 41 here
with an admendment
with an amendment of only connecting the DSL cable to BT Socket (Via a filter if needed) after you have changed the correct setting to ([email protected]) with your plusnet password and saved by pressing the tab at top of the page.
Do not have any odd symbols in your  plusnet password. The BT Hub will not take them. ie %^&*()+£ etc
https://community.plus.net/t5/ADSL-Broadband/BT-Home-Hub-6-Smart-Hub-on-PlusNet/m-p/1415464#M312705
slao see
post by Baldrick1 which relates to the Business Hub version.
https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/td-p/1587673
LifeonMars
Seasoned Pro
Fixes: 12
I am uncertain about the disc however
I use the Smart Hub2  with no problem
Fixes: 480
@LifeonMars
Is it true that you can't separate the bands on the Smarthub 2? If so have you heard of this causing issues?
LifeonMars
Seasoned Pro
Fixes: 12
Yes it is true, you are unable to seperate them on a Smart Hub 2, however had no issues.
