Audio GAIN equalizer for LINUX MINT
shutter
Fixes: 67
looking for some software that will equalize the audio gain level on all my music videos
for making audio cd`s for the car... there is a program called   MP3GAIN... where you can input your audio files.. -ripped from the video- and then with the flick of a mouse tail.. it will equalise the volume level  or gain...
there is a newer version for doing the same thing to actual music videos called MP4GAIN... but this is a trial version and costs 40 USD.. for the =registration=  it was written for windows, but would run on linux through wine...
being a Yorkshireman... I don`t want to spend any money on software, if there is a free version...
so... anyone know of a similar type FREE SOFTWARE that would be able to do this
6 REPLIES 6
Mook
Seasoned Champion
Fixes: 9
Re: Audio GAIN equalizer for LINUX MINT
If you install FFMpeg you can do it using this but you may want an easier solution.
shutter
Fixes: 67
Just checked the software manager... and it seems that I already have ffmpeg installed...
BUT.. from what I have read ( after googling "what is ffmpeg"..). it seems to be  a "long winded" way of converting music files from  file type AAA to file type BBB (or whatever the file extension is) .
ANYVIDEO CONVERTER will do that, simply, and efficiently.... and is not what I want to do..
Some videos have the music track at ( say 100% volume)  ( need to reduce the headphone volume for comfort) .. and others   have the music track, sometimes as low as 50% volume..
MP3GAIN  would "equalise" all the volume levels, for a AUDIO CD... for use in the car...
MP4GAIN would (presumably) do the same for music videos...which is what I would want to achieve, so that I am not having to reset the volume on a "playlist" of videos.
At present... the only way I "could", probably, achieve this would be to "re-record" all my music videos, using VOKOSCREEN.... which would take a very very long time
Mook
Seasoned Champion
Fixes: 9
No pleasing some folk!
https://trac.ffmpeg.org/wiki/AudioVolume
shutter
Fixes: 67
@Mook   True......  very true !.....
( you know I am a numpty with linux...   ! )
I see at the bottom of that page... there is some sort of instruction on how to "batch" normalise a group of files... so... might have a try of that....but........  Undecided
Having clicked on the red ffmep-normalize Python program...... it takes me to a github page, and from there on... it`s like reading a chinese takeaway menu, without the english translation...
so... give up on that ....
VOKOSCREEN... here I come   Cheesy
Mook
Seasoned Champion
Fixes: 9
You needn't worry about batch processing at the moment @shutter, the first thing to do using those instructions is to get a couple of files done by hand to see if you get the results you expect.
I don't think you'll need a Python program to do batching when, in theory, a shell script will do what's needed.
shutter
Fixes: 67
@Mook  Partly understood   ! ! ! ...
Minor crisis at this end at the moment... so will put it on the back burner for today, at least.!
cheers
Wink
