Anyone used Zorin OS ? (core version)
ITWorks
Fixes: 8
Hi has anyone used Zorin OS ?
Having never used Linux before, and having a laptop with the awful Vista on, thought i would put a Linux distro on it.
After having a quick look around decided to go with the above (just downloading)
http://zorin-os.com/index.html#
Any hints and tips would be much appreciated Smiley
Regards
Mike
2 REPLIES 2
VileReynard
Fixes: 20
Re: Anyone used Zorin OS ? (core version)
Zorin OS is a multi-functional operating system designed specifically for Windows users
who want to have easy and smooth access to Linux.
It is based on Ubuntu which is the most popular Linux operating system in the world.
HairyMcbiker
All Star
Fixes: 21
Nope never used it, the menu looks a bit like the Mint menu though. You are on your own with this one.
