Another Open Office problem
FIXED- Subscribe to RSS Feed
- Re: Another Open Office problem
28-04-2017 6:49 PM
I`ve been using spreadsheets for a while, and not seen this before... can anyone tell me how it started and how to end it...
When I want to enter a new row of data I go to "insert" "row" and it would normally just put a new row of empty cells above the place where the cursor was... and the first cell would be surrounded with a heavy black outline, ready to accept the data.
recently, there has been a pair of red lines right across the spread sheet, and when I have entered and saved the data, those lines are still there.... and remain there, even though I try to enter new data on a lower row level,
I must have clicked on something by accident.. but I don`t know what the purpose of the red lines are, so I don`t know what to look for to "un check" it...
anyone help remove these red lines... forever, please.!
Fixed! Go to the fix.
28-04-2017 7:38 PM
Sounds like you have Track Changes on.
Look at: Edit > Changes > Record and make sure it isn't selected.
28-04-2017 8:09 PM
Five Stars to you @SpendLessTime That has cured the problem... many thanks
28-04-2017 8:46 PM
Welcome
