SQL server 2000 - any gurus?
chenks76
All Star
Fixes: 12
i have a query running on SQL server 2000
declare @selecteddate datetime
set @selecteddate = '13 March 2017'
select
diary_engineer_id, diary_start_date, diary_end_date
from diary with (nolock)
where diary_link_to_nonprod in ('HO','LD')
and (@selecteddate <= diary_end_date) and (@selecteddate >= diary_start_date)
and diary_engineer_id in ('C000021','GB','GC','JA','JMCF','KYLEM')
order by diary_engineer_id, diary_end_date
which produces the result
C000021	2017-03-13 00:00:00.000	2017-03-17 00:00:00.000
GB	2017-03-13 00:00:00.000	2017-03-13 00:00:00.000
GC	2017-03-13 00:00:00.000	2017-03-13 00:00:00.000
JA	2017-03-13 00:00:00.000	2017-03-17 00:00:00.000
JMCF	2017-03-13 00:00:00.000	2017-03-13 00:00:00.000
KYLEM	2017-03-13 00:00:00.000	2017-03-13 00:00:00.000
what i need it to do is produce a row for each of the dates within the daterange in each resulting row.
so essentially in this example i would want it to produce
C000021	2017-03-13 00:00	2017-03-13 00:00
C000021	2017-03-14 00:00	2017-03-14 00:00
C000021	2017-03-15 00:00	2017-03-15 00:00
C000021	2017-03-16 00:00	2017-03-16 00:00
C000021	2017-03-17 00:00	2017-03-17 00:00
GB	2017-03-13 00:00	2017-03-13 00:00
GC	2017-03-13 00:00	2017-03-13 00:00
JA	2017-03-13 00:00	2017-03-13 00:00
JA	2017-03-14 00:00	2017-03-14 00:00
JA	2017-03-15 00:00	2017-03-15 00:00
JA	2017-03-16 00:00	2017-03-16 00:00
JA	2017-03-17 00:00	2017-03-17 00:00
JMCF	2017-03-13 00:00	2017-03-13 00:00
KYLEM	2017-03-13 00:00	2017-03-13 00:00
is this possible?
Tags (1)
26 REPLIES 26
mike4262
Re: SQL server 2000 - any gurus?
chenks76
All Star
Fixes: 12
actually that isn't quite the same thing.
as i am only passing 1 date into the query, not two.
i am not looking for the dates between two date variables.
jelv
Fixes: 10
I would set up a calendar with all the possible dates and then cross join the results "where calendar.date between diary_start_date and diary_end_date"
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
@chenks76 - What happens when you change the order of the predicate, from :
to something like :
and (diary_end_date <= @selecteddate) and (diary_start_date >= @selecteddate)
jelv
Fixes: 10
Incidently, why not instead of
did you not use
and (@selecteddate between diary_start_date and diary_end_date)
which is much easier to read?
jelv
Fixes: 10
@Anonymous That's still only going to return one row for each row in diary.
chenks76
All Star
Fixes: 12
to something like :
that produces 2 less records, which would be a wrong outcome.
and doesn't give the desired multiple rows anyway.
chenks76
All Star
Fixes: 12
did you not use
that produces the same results for the test sample. but the ease of the readability is not my primary concern at the moment Cheesy
chenks76
All Star
Fixes: 12
will that not add an extra overhead on the run time of the script?
the supplied query is just a small test sample, but in theory it could include many rows.
mike4262
True but you could get the diary start date and end date into variables as a first step and then use those dates to generate the data you want.
something like this;
select
    @diary_start_date_var = diary_start_date,
    @diary_end_date_var = diary_end_date
from
    diary
where
chenks76
All Star
Fixes: 12
but where are these two new variable getting the data from?
only the original varibiale called "selecteddate" is passed into the query (which comes from elsewhere).
only diary_start_Date will always be the same (from the original variable)
diary_end_date could be anything.
Exactly @chenks76 so it proves that the ordering within the predicate is important. You can now work the rest out knowing that.
jelv
Fixes: 10
The overheads of a calendar table would be minimal and you'll have the dates as the primary key so the join will be quick.
chenks76
All Star
Fixes: 12
i'm not sure i follow your thought process there.
my original ordering gives the correct outcome, your amended one gives the wrong outcome.
