Android Lollipop 5 and above (ie subsequent updates)
nozzer
Not sure where to put this...  anyone using this o/s on a Nexus device which has difficulty holding on to a 5GHz wifi signal, meaning it keeps dropping out with anything other than a 100% signal? If so, have you discovered any work-arounds?
11 REPLIES 11
nozzer
Re: Android Lollipop 5 and above (ie subsequent updates)
@Strat...  this is neither Mac nor Linux!!
Strat
Fixes: 565
I know but it should be Android also Wink
Other Android stuff ends up in here.
In any case I'm not having a good day Sad
shutter
Fixes: 65
Quote from: nozzer
I agree with you,,. I even posted stuff about my ANDROID tablet in Hardware..........
You would think, by now, that some MODS and some PLUSNET STAFF would have got their act and heads together, and .....
A Renamed the Mac/Linux to include Android,
B. Opened a new board for Android......
bobpullen
Fixes: 316
Quote from: nozzer
I've not noticed a problem using a HomeHub5, a Nexus 7 (2013) and a Nexus 6 (although the latter is currently running Android M).
DaveyH
Champion
Fixes: 12
Android 4.4 broke 5GHz on my Nexus 4 and haven't been able to connect to any network on the 5GHz band since. None of the suggested fixes I could find have ever worked..
gleneagles
Aspiring Legend
Fixes: 17
Quote from: shutter
Quote from: nozzer
I Think this has been suggested before.................but clearly not taken up
Smiley
We are born into history and history is born into us.
Fixes: 1,484
As Android is based on a LINUX kernel it doesn't need changing.
twocvbloke
Quote from: nozzer
https://en.wikipedia.org/wiki/Android_%28operating_system%29
shutter
Fixes: 65
Quote from: dvorak
And..... as Michael Caine said.......
"Not a lot of people know that"....        (nor do they care...... to them, it is Android... )
so it should be in the title......
bobboulby
To return to the original question. I've got Lollipop running on a Nexus 4 and 2013 Nexus 7 - no problems with 5GHz on an Asus RT-N66U.
Bob.
nozzer
The only channels I've managed to (sort of) get 5GHz working on are 36 and 48. Dualling the bandwidth wrecks it. It was fine with Android 4.4.4.
However, I take comfort in knowing that lots of people seem to have this problem, even if Google aren't doing anything about it!
