After EE switch-over one device won't connect
Buggwrit
Re: After EE switch-over one device won't connect
@pvmb  "Well yes, why wouldn't it?"
I don't know. I'm just prepared to clutch at straws to try and get this working.
In answer to your questions I have been able to log into my Greenby account. Interestingly the client settings for the email account don't seem to bear any relation to those in Thunderbird that have been working for months. This is what is shown:
and these are the settings for the incoming mail in Thunderbird:
I have also logged into webmail and tried sending a test message which appears to have been successful.
pvmb
Aspiring Champion
Fixes: 15
@Buggwrit
The normal settings for someone with a Plusnet account, using POP protocol would be -
Incoming Server Address:  imap.plus.net [91.204.208.26] (aka mail.plusnet.enmail.co)
Protocol: POP
Port:  995 (Encryption Enabled)
Outgoing Server Address:  relay.plus.net [212.159.8.107]
SMTP Port:  465 (Encryption Enabled)
However, you can see above that relay.plus.net is in the Plusnet domain IP address range. Whereas relay.force9.net [91.204.208.196] is in the Greenby/Enix domain IP address range, as is  mail.plusnet.enmail.co [91.204.208.26] (same IP as imap.plus.net/mail.plusnet.enmail.co) so, if you have now left Plusnet, you may have to use one of these servers instead of relay.plus.net  [212.159.8.107] to send mail.
Although mail.plus.net [91.204.208.26] that you quote as using for sending SMTP mail is also a Greenby/Enix domain host, it is the IP address for incoming mail - imap.plus.net [91.204.208.26]
bobpullen
Fixes: 330
@Buggwrit wrote:
Thanks @Dan_the_Van  and @PhilipHeyes . After reading the link on setting up compatible wi-fi I really thought that would be the answer.
Unfortunately it hasn't made any difference. I first enabled the compatible 2.4GHz wi-fi but that didn't help. I then tried turning the non-compatible 2.4GHz off but again no difference. I've tried restarting the PC and then finally resorted to trying the 'Manage wireless networks' in the Network and Sharing Centre and manually adding both the standard and -Comp network names to the list, with the -Comp at the top which Windows will try first.
Still nothing. When I open 'Connect to a network' neither of them appear in the list, just neighbouring networks. Very frustrating.
Just to comment on the WiFi element: -
Compatible WiFi won't work as it still uses WiFi6/AX and I strongly suspect this is the crux of your issue. I've seen it before with older network cards using Reatek chipsets (which I believe this Asus card might).
Plenty of reports of similar out on the Internet e.g. here.
Buggwrit
Hi Bob, yes I've come to the conclusion it's a protocol problem. I investigated newer PCI-e cards but I strongly suspect they won't support Windows 7. I'm currently investigating whether I can arrange a suitable route for a twisted-pair connection to the hub. The PC that I'm sending this from is a wired connection but the location of the problem one is more awkward which is why I opted for wi-fi.
PhilipHeyes
Aspiring Champion
Fixes: 17
@Buggwrit are you still dealing with Password failure from relay.force9.net ?
If Yes :
1) make sure the Username is the email address of the mailbox  ( i.e. not <account>+<name> and not an alias )
2) relay.force9.net is a server hosted and managed via the Greenby portal,  use the Greeny portal to reset the password for the relevant mailbox and the new credentials will be applied to the force9 servers for  imap, pop3 & smtp
Changing passwords in the Plusnet portal does not change the password of relay,force9.net or for any other Greenby hosted mail servers that have an IP in for form : 91.xxx.xxx.xxx
Fixes: 479
@Buggwrit
You could try using a WiFi extender. If you get a WiFi 5 one that will connect to the EE hub, you could use the WiFi 5 output to connect to the pc.
PhilipHeyes
Aspiring Champion
Fixes: 17
@Baldrick1 Cracking idea  !
The exact same problem exists in the Virgin Media world where Hub 5 has Wi-Fi 6 & it can not be disabled & does not work with a wide range of computers / printers / IoT / CCTVs
The device that is considered to work in this bridging role is : TP-LINK RE450
https://www.screwfix.com/p/tp-link-re450-ac1750-dual-band-wi-fi-range-extender/6372r
Buggwrit
@PhilipHeyes  & @Baldrick1
That's a very interesting idea. Although I could get a twisted-pair cable for half that price installing it would be physically demanding for an 82-year-old so if I could be reasonably confident the extender would work I'd definitely prefer that.
Buggwrit
@PhilipHeyes
If Yes :
Yes, I haven't resolved that yet. Thanks for your input. I do have a Greenby account which allows me to make the kind of changes you've suggested but I had assumed that since webmail works my credentials are correct. However I'm ready to try anything that might work. To be honest I've been taking a break from all this because having 3 different sets of problems to deal with at once it was all getting a bit too much.
PhilipHeyes
Aspiring Champion
Fixes: 17
@Buggwrit a network cable is the way to go if that is possible.
When it comes to cost, the RE450 was often bought by people with many IoT / CCTVs its cost was little in the scheme of things.   If cost saving is important dual band USB Wi-Fi adaptor is also available for less than £25.
You mentioned Webmail works.   Which webmail works, the Plusnet one or the Greenby one ?
I ask because I suspect the Plusnet webmail uses SMTP relay.plus.net
whilst the Greenby webmail uses an SMTP like relay.force9.net or mail.enmail.co
At the moment it appears possible to have different passwords on the SMTP of the Plusnet and the Greenby platform,
I know this is getting into the weeds of detail.  But often that is where the solution to a problem lies.
Buggwrit
@PhilipHeyes  The URL of the webmail is webmail.greenby.com from which I assume it's the Greenby one.
Cost saving isn't a major issue. If the one you linked from Screwfix will do the job I'm happy to go with that. I'll be in the vicinity of a Screwfix on Thursday so can do a click-and-collect .
Buggwrit
@PhilipHeyes
I agree a network cable would be the best way to go but I think installing it would severely test my physical capabilities so I've ordered the extender from Screwfix. I'll be collecting it on Thursday. Fingers crossed. If it works I'll be eternally in your debt. If it doesn't I promise not to hold it against you 😊.
I started to do a search for USB adaptors the other day but I am a bit concerned that a modern dual-band one might not be compatible with Windows 7.
PhilipHeyes
Aspiring Champion
Fixes: 17
@Buggwrit
The manuals and so on for the RE450 are here :
https://www.tp-link.com/uk/home-networking/range-extender/re450/
