3G Wireless Dongle with Linux Mint 9 Isadora
- Re: 3G Wireless Dongle with Linux Mint 9 Isadora
- « Previous
- 1
- 2
- Next »
31-07-2011 7:50 PM
configuration #1 chosend from 1 choice
SCSI3 SCSI emulation for USB mass storage devices
usb storage ; device found at 4
usb storage; waiting for device to settle before scanning
SCSI4 ; SCSI emulation for USB mass storage devices
usb storage; device found at 4
usb storage; device scan complete
scsi 3;0.0.0. CD-ROM HUAWEI Mass storage 2.31 PQ : 0 ANSI ; 2
usb storage. device scan complete
scsi 4;0;0;0/ Direct - Access HUAWEI TF CARD Storage PQ ANSI; 2
SRL; SCSI - 1 drive
sr 3;0;0;0 Atttached scsi CD-Rom ROM sr1
sr 3.0.0.0 attached scsi generic sg2 type 5
sd 4.0.0.0 attached scsi generic sg3 type 0
sd4.0.0.0 [sdb ] Attached scsi removable disk
ISO 9660 Extensions: Microsoft Joliet Level 1
ISOFS; changing to secondary root
wlan0 . deauthenticating from 00.xx.xx.xx. by local choice (reason3)
(above line repeated)
wlan0 . direct probe to AP 00: xx;xx;xx (try 1)
direct probe responded
authinticate with ap 00:xx;xx;xx (try1)
authenticated
associate with ap 00:xx;xx;xx (try1)
RX AssocResp from 00:xx;xx;xx (capab=0x411 status-0 aid=2)
wlan0 : associated
31-07-2011 8:05 PM
Can you post the output of the lsusb command with the device plugged in, that should tell us what device it is. it should look something like this
Quote linux:~$ lsusb
Bus 002 Device 002: ID 093a:2510 Pixart Imaging, Inc. Hama Optical Mouse
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
31-07-2011 8:23 PM
Bus 005 device 001 id 1d6b 0001 Linux Foundation 1.1 root hub
Bus004 ditto
Bus 003 ditto
Bus002 device 004 ID 1bcf 0007 Sunplus Innovation Technology Inc.
Bus002 device 001 id 1d6b 0001 Linux Foundation 1.1 root hub
Bus001 device 004 id 12d1 1446 Huawei Technologies Co., Ltd.
Bus001 device 001 id 1d6b 0002 Linux Foundation 2.0 root hub
31-07-2011 9:39 PM
You could try installing or updating the usb-modeswitch and usb-modeswitch-data packages. The usb-modeswitch package contains a program which (automatically) tells these kind of devices to stop pretending to be a CDROM and become a modem.
31-07-2011 10:17 PM
or even Ubuntu 11.04
any comment or advice ? regarding that action? ? ? ?
31-07-2011 10:38 PM
Installing a newer distribution is better than having to install newer individual bits and pieces to get support for newer hardware. The updates released for Mint 9 will be mostly bug fixes and security updates, but not usually newer versions of things.
Mint 11 is available, based on Ubuntu 11.04.
31-07-2011 10:51 PM
will close this thread, and also the other one.....
Thanks for all the help guys..... stand by ! ! !
31-07-2011 11:05 PM
Quote from: ejs That pair of usb ID numbers (12d1:1446) is present in the latest version of usb-modeswitch-data, so I assume it would "just work" with a more recent Linux distribution.
Oddly enough the Mint 9 LiveCD usb-modeswitch also has those USB IDs:
mint@mint ~ $ cat /etc/usb_modeswitch.d/12d1:1446
# Huawei E270+ (HSPA+ modem)
DefaultVendor= 0x12d1
DefaultProduct=0x1446
TargetVendor= 0x12d1
TargetProductList="1001,1406,140c,14ac"
CheckSuccess=20
MessageContent="55534243123456780000000000000011060000000000000000000000000000"
Which differs from the Mint 11 12d1:1446 entry in /usr/share/usb_modeswitch/configPack.tar.gz:
# Huawei, newer modems
TargetProductList="1001,1406,140b,140c,1412,141b,1433,14ac"
CheckSuccess=20
MessageContent="55534243123456780000000000000011062000000100000000000000000000"
Dunno if replacing the old with the newer would work, though.
- « Previous
- 1
- 2
- Next »
