terrible service n naff speed
- Feedback
- Plusnet Feedback
- terrible service n naff speed
28-12-2011 6:36 PM
Re: terrible service n naff speed
28-12-2011 8:23 PM
I have reviewed your connection and can see that your current line speed is slightly lower than your line speed estimate. Your line is estimated to achieve 3500kbps but is currently performing at 1944kbps. Have you tried connecting your broadband router to your telephone line's master or test socket as pictured below?
If not, please connect your router there and reply to this thread so we can retest your line. Bear in mind the router will need to be connected to the test socket when we re-run our line test. You will not see an immediate increase in your speed at your side by simply connecting your router as above.
28-12-2011 9:24 PM
28-12-2011 9:29 PM
28-12-2011 10:04 PM
As used on new build properties.
These are wired to a normal line jack socket inside
There is therefore no internal test point available to the user
just a thought.......
29-12-2011 1:19 AM
If you're getting a download speed of 490 Kbps you can be absolutely certain this has nothing to do with the service from Plusnet and everything to do with the way your equipment is connecting to them. So, if the situation is going to improve, you need to calm down and take some action yourself to help improve it.
Plusnet are not going to ask for a BT engineer to go out and investigate until they are sure the problem is not on your side of the master telephone socket. That is why they ask for you to undertake various checks first. (If you cut corners on this and BT go out and find the problem wasn't with their line, then you will be liable for a hefty call-out charge.)
Your only alternative, if your local circumstances allow, is to cease the BT connection altogether and sign up with an LLU, cable or satellite provider -- something which, you rightly say, will really cost you.
Sorry if this isn't what you wanted to hear (and sorry that you're having problems in the first place).
Chris
29-12-2011 11:26 AM
29-12-2011 12:50 PM
I've just chased the callback for you, that should be happening shortly though there seems to be some question over whether you'd like us to continue the fault investigation? Please let us know if you would and we'll get on it for you.
Really sorry about the delay on the callback.
29-12-2011 8:47 PM
As discussed, an engineer is booked to visit you tomorrow to complete enhancements to your line and boost the speed to the maximum possible level. We will follow up on the case post visit to obtain the notes from the engineer and retest your line to check for any improvement. If you have any problems then please let us know by updating your support ticket.
31-12-2011 11:58 AM
then i was given the answer .cos we cant give the service we will reduce the cost to accomidate sorry plus net i want to pay my bills and in turn you should provide a good service also im not shure that you should be blaming bt as youre OWNED BY BT as a good will you should cancel my contract free of charge due to crap service id never recomend the so called yorkshire based internet provider you should state BT INTERNET PROVIDER 7 weeks of on goin crap never again sorry plusnet ooops BT
03-01-2012 11:11 AM
Please accept our apologies for the issues you are experiencing. There are two separate issues affecting your account currently.
Firstly the line speed fault. I have reviewed your account following the engineer visit and found that further adjustments to the way your connection operates are required. I have begun this process but due to the time the adjustments take to complete (usually approximately 24 hours each) I cannot complete this process fully until 05/01/12. I am personally monitoring your account to ensure this is completed successfully.
Secondly, you have hit your account usage allowance which is causing your line speeds to be restricted. We can add further usage to your account at a cost of £5 per 5GB of usage but you have set a maximum spend on your additional usage at £5 which means no further usage is being added automatically. If you would like to increase this to allow an additional 5GB of usage for £5 then you can do this within the members centre at the following link:
https://portal.plus.net/data_transfer_watch/
You will need to increase your maximum additional usage spend to at least £10 for the restriction to be lifted. Alternatively your account usage will reset on your next billing date of 06/01/12 anyway.
I can understand your frustration on this matter but we are only a few days away from completing the work on your line to provide higher speeds. We appreciate your patience during this time.
03-01-2012 10:41 PM
04-01-2012 9:20 AM
I will have all the necessary line adjustments to stabilise your connection complete by the end of day today and I will monitor to ensure your usage allowance resets and your speed improves to normal levels.
04-01-2012 11:53 PM
jim:red All Caps removed as per Forum Rules mod:end
05-01-2012 7:20 AM
My equipment is correctly connected though.
Configured as per the set-up guides and with excellent help from Techies at PN.
Here's another clue......
"Secondly, you have hit your account usage allowance which is causing your line speeds to be restricted"
When my download speed sometimes "appears" to slow down, it is usually down to multiple (20+) tabs open in browser
I Bookmark all, reboot browser, reopen 5 tabs at a time cures the "apparent" speed issue every time
