so good you send them twice
whistler
why do PN allways send me every email twice?
25 REPLIES 25
pierre_pierre
Re: so good you send them twice
cause they send one to postmaster and one to your nominated default
adamwalker
Fixes: 221
whistler,
Check what addresses they were sent to and let us know if they are different. If this is annoying you we can give you some advice on getting around this.
Adam
 Adam Walker
pierre_pierre
and check the envelope to address, mine doesnt show up in the e-mail index
pierre_pierre
I spoke to soon
just got three, two to my Postmaster@username.free-online.co.uk and one to postmaster@usename.me.uk
whistler
Quote from: _Adam_Walker_
Each one is addressed to 2 addresses, postmaster@... and me@...
ChrisL
Quote from: pierre_pierre
and check the envelope to address, ....
Wink
pierre_pierre
and how do you think I knew who they were addressed to?
Santiago
I have started to get two emails, one to username etc@f9.co.uk which is correct but I am also getting one now to username etc@force9.co.uk.
I had this issue a while ago and it was sorted (don't remember how)
adamwalker
Fixes: 221
Oddball,
Yes, I do remember that happening in the past at some point, I'll get that looked into.
whistler,
How do you check your e-mail? do you use a client like Outlook or do you use webmail?
 Adam Walker
whistler
outlook
adamwalker
Fixes: 221
Thanks,
It sounds like your Outlook is set up to receive mail to both the postmaster address and your me@ address. I'd advise changing your settings to only pick up from the me@ address to stop this.
Please read these help pages as they should explain how to do it:
http://www.plus.net/support/email/email_explained.shtml
http://www.plus.net/support/email/setup/outlook_2007.shtml (for Outlook 2007)
http://www.plus.net/support/email/setup/outlook.shtml (for Outlook 2003)
If you end up struggling with this drop me a PM and I'll give you a call.
Adam
 Adam Walker
pierre_pierre
why did I get two to the same adress on consecutive days?
Return-path: <padmin@pih-cronhost01.servers.plus.net>
Envelope-to: postmaster@peter.free-online.co.uk
Delivery-date: Tue, 26 Oct 2010 13:55:13 +0100
Received: from [212.159.7.38] (helo=mx.ptn-ipin03.plus.net)
  by pih-inmx09.plus.net with esmtp (PlusNet MXCore v2.00) id 1PAj3Y-00046r-Ko
  for postmaster@peter.free-online.co.uk; Tue, 26 Oct 2010 13:55:12 +0100
Received-SPF: None identity=pra; client-ip=84.92.1.97;
  receiver=mx.ptn-ipin03.plus.net;
  envelope-from="padmin@pih-cronhost01.servers.plus.net";
  x-sender="autoemail@plus.net";
Delivery-date: Wed, 27 Oct 2010 13:04:44 +0100
Received: from [212.159.7.39] (helo=mx.ptn-ipin04.plus.net)
  by inmx14 with esmtp (PlusNet MXCore v2.00) id 1PB4kG-0007vS-2G
  for postmaster@peter.free-online.co.uk; Wed, 27 Oct 2010 13:04:44 +0100
  receiver=mx.ptn-ipin04.plus.net;
plus one to my other address
Envelope-to: postmaster@peter.me.uk
Delivery-date: Wed, 27 Oct 2010 13:04:57 +0100
  by inmx18 with esmtp (PlusNet MXCore v2.00) id 1PB4kT-0006Ih-30
  for postmaster@pete.me.uk; Wed, 27 Oct 2010 13:04:57 +0100
adamwalker
Fixes: 221
pierre_pierre,
There's no obvious reason that I can either see or think of. I'll have to look into that and get back to you.
Adam
 Adam Walker
whistler
Nope. My outlook is set up to receive from just my me@ address. The reason I'm getting them twice is cos you're sending them twice. As I said in post #5 you send me TWO - BOTH addressed to TWO addresses, postmaster@ and me@. i.e. you're actually sending FOUR - two to postmaster@ which I DON'T get and TWO to me@ which I DO get.
