rDNS changed back to default
- Feedback
- Plusnet Feedback
- rDNS changed back to default
Re: rDNS changed back to default
07-02-2015 5:52 PM
Quote from: pwatson I don't believe that mine is due to change - 84.92.0.0/16 isn't in the published range?
If you've not received the email notification (also viewable on account tickets) by now then your IP address won't be changing.
In that range there are some that are changing as we're in it and are scheduled to be changed over next month.
Ah, ok then Jim. That's cleared things up. So it's NOT linked to the static IP change, either scheduled or already happened.
07-02-2015 6:40 PM
F9 ADSL customer since 2004
F9 FTTP customer since 2024
07-02-2015 7:46 PM
07-02-2015 7:52 PM
edit: ticket 98961427 if it helps to link it to the problem
07-02-2015 8:08 PM
maybe they're looking into the root cause and doing a mass rollback..
07-02-2015 8:30 PM
07-02-2015 8:51 PM
Here's me wondering also if a mass script has been run to set every PTR record to the default to get rid of stale records. I must say, when I first got my static IP that it had an invalid PTR record for a former customer and it was a good thing I requested my own straight away on being allocated the IP. I can see here a scenario- PlusNet are trying to fix a long-standing problem but have sweeped up legitimate valid records along the way. Either way, please fix it PlusNet! EDIT: I've raised a ticket #98961463 regarding this.
[Moderator's note by Jim (Oldjim) username masked ]
EDIT 2: Sorry mods, I will refrain from mentioning my broadband username in the future.
EDIT 3: Domain changed to 'example.uk'.
07-02-2015 9:22 PM
07-02-2015 10:32 PM
Ticket has been raised.
Many thanks to the OP for bringing it to our attention. I await Plusnet's response with interest.
08-02-2015 12:29 AM
08-02-2015 4:05 AM
08-02-2015 11:23 AM
08-02-2015 12:00 PM
08-02-2015 1:07 PM
08-02-2015 1:41 PM
