rDNS changed back to default
RPMozley
Seasoned Pro
Fixes: 16
Re: rDNS changed back to default
Quote from: pwatson
I don't believe that mine is due to change - 84.92.0.0/16 isn't in the published range?
If you've not received the email notification (also viewable on account tickets) by now then your IP address won't be changing.
In that range there are some that are changing as we're in it and are scheduled to be changed over next month.
Ah, ok then Jim. That's cleared things up. So it's NOT linked to the static IP change, either scheduled or already happened.
That's RPM to you!!
avatastic
one of my netblock has changed to the default, the router, broadcast and one of the other usable addresses are currently unchanged.
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
KevinG
Mine has reverted back as well. Are we supposed to raise tickets individually?
Gus
ditto, raise a ticket or is reply here enough?
edit: ticket 98961427 if it helps to link it to the problem
FTTP 500 regrade from Tues 28th November
Fixes: 1,493
I raised a ticket a few hours ago but haven't heard anything back as yet.
maybe they're looking into the root cause and doing a mass rollback..
jelv
Fixes: 10
The help assistant path to ask for this to be changed is: https://www.plus.net/wizard/?p=wizard&page=22425&wizard_id=38
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
samspin
I have also noticed today this has happened on my static IP. It should be set as 'wireroom.example.uk' but has been sent back to the default 'username.plus.com' without my knowledge.
Here's me wondering also if a mass script has been run to set every PTR record to the default to get rid of stale records. I must say, when I first got my static IP that it had an invalid PTR record for a former customer and it was a good thing I requested my own straight away on being allocated the IP. I can see here a scenario- PlusNet are trying to fix a long-standing problem but have sweeped up legitimate valid records along the way. Either way, please fix it PlusNet! EDIT: I've raised a ticket #98961463 regarding this.
[Moderator's note by Jim (Oldjim)  username masked ]
EDIT 2: Sorry mods, I will refrain from mentioning my broadband username in the future.
EDIT 3: Domain changed to 'example.uk'.
drunkenmonkey
Yep mine has reverted back as well. Will wait and see an official response on this thread before raising a ticket.
toggie101
Yep, mine has also been reset to the default config.
Ticket has been raised.
Many thanks to the OP for bringing it to our attention. I await Plusnet's response with interest.
Jaggies
It's got mine as well...
samspin
I've just checked and mine appears to have been reverted, I wonder if they have indeed done a bulk undo?
thesawdust
mine's gone back to what it was previously. Reported by ns1.force9.net on 2/8/2015 at 5:22:43 AM (UTC -6)
Jaggies
Mine's sorted as well, just a few seconds before 6am this morning.
pwatson
Mine has reverted as well...
Fixes: 1,493
yup, mine's looking ok too now.
