plusnet dealing with public
- Feedback
- Plusnet Feedback
- Re: plusnet dealing with public
29-11-2016 2:43 PM
i wonder how we could get plusnet to answer our calls sooner ive waited up to 37 mins now if i ask amazon to phone me i get a call in seconds!!!
my download speed was 0.01mbs!! so i have to phone plusnet am i missing something in the olden days one could e mail raise a ticket get your line checked but not now you have to listen to someone telling you what to do but you have done that just get my speed up
who says ill be renewing my contract?
30-11-2016 2:08 PM
Are you still having problems with your download speeds? I've made a couple of changes to your profile which should hopefully improve things a little bit.
30-11-2016 2:19 PM
Moderator's note by Dick (Strat) Off topic, irrelevant and insulting posts removed.
30-11-2016 2:20 PM
Not yet ladddie
27-02-2017 11:00 PM
Is this the best you can do?
| 2/27/2017 10:49 PM GMT | 87.115.221.223 | 0.62 Mb/s | 0.36 Mb/s | 343 ms |
28-02-2017 10:56 AM
Hi there
I've tested your line and I'm not detecting a problem.
| Upstream DSL Link Information | Downstream DSL Link Information | |
| Loop Loss: | 30.5 | 61 |
| SNR Margin: | 12 | 10 |
| Errored Seconds: | 1 | 0 |
| HEC Errors: | 0 | 0 |
| Cell Count: | 2173 | 2534 |
| Speed: | 448 | 2080 |
Are you connecting wirelessly or using a wired connection?
28-02-2017 2:09 PM
Both averages out the same there was a drop in speed now gone up to 1.69 but nowhere near the2.31 on 18/2/17
I would say there is a problem
bill
28-02-2017 3:02 PM
Sorry to hear about the drop in speed. At the moment, your throughput of 1.69 Mbps is looking OK.
If the problem happens again, please can you run a speed test at http://speedtest.btwholesale.com, being sure to complete the further diagnostics after the first test completes then raise a fault to us at http://faults.plus.net
02-03-2017 3:17 PM
1.69 is not good when ive been getting 2.31!!
