plus.net running really, really slow
I went to the plus.net site twice this morning and each time it was running very very slow, this last time it took nearly 1 minute to load and this is what I got when it had finished!
60 seconds later...
 Also the labels for posting are very limited and the one chosen has no bearing on this issue, I only selected it to allow me to post.
12 REPLIES 12
Fixes: 251
Re: plus.net running really, really slow
Briefly this morning also I could not connect to the community.
Well to be fair the only issue I have had is with the plus.net site, community has been fine for me so far at least.
gsha
There's definitely something not right!!
It maybe that there is an update in progress. If so not the best of timing if you ask me, and if you don't ask me, it's still not the best of timing!
rongtw
Fixes: 12
yes i tried to connect 10 mins ago and got this Undecided
Gel
Champion
Fixes: 29
Fixes: 251
This is an issue Plusnet is investigating - have requested a service status notice.
The site appears to be working now, so I think my assumption about the update may have been correct, and I'll assume this until such a time as I am told otherwise.
jaread83
Fixes: 81
@Anonymous, your assumption is not correct - we only do software releases to the website overnight when there isn't much traffic.
The issue has been resolved and there is a service status post about it here: https://community.plus.net/t5/Service-Status/Intermittent-Website-Issues/m-p/1504376#M256
Thanks for clarifying that @jaread83, I am now a wiser man. The status update doesn't say what was wrong, so are you able to share the reason?
jaread83
Fixes: 81
I don't know any of the finer details of what went wrong exactly but from what I can gather from asking one of the teams involved I have been told there was a latency issue with the site.
Fair enough @jaread83, I appreciate it's not within your remit, but the response you got from the team, is nothing more than stating the obvious. Maybe @LouisaMartin's status updates will shed some light on it for the nosey ones like me. Wink
