is my pro package all it should be??
- Feedback
- Plusnet Feedback
- is my pro package all it should be??
20-07-2010 2:05 AM
I've recently upgraded to the pro package my expected line speed is 13mb but i must admit to not knowing how to read these kb, kB/s
after 12am i usually get a great speed but feel I'm being speed shaped during the daytime and evening which is what i upgraded to pro to avoid
I like coming in in the evening and watching a film online but recently have been getting some lousy results and hoped you experts could make sense of these various readings from mybroadbandspeed and explain to me weather I'm getting normal results (for PN) or something is way out of wack
i will provide any other info ness on request
get this speed alot between 5pm and 11pm
one of the faster speeds I achieve
Re: is my pro package all it should be??
20-07-2010 8:30 AM
20-07-2010 9:02 AM
Do you find that the speeds jump up at a particular time, or is it a more gradual increase?
You're definitely being profiled correctly on our network and speedtest traffic should be prioritised highly regardless of your package.
Are the speeds consistent across other speed checkers? I'm particularly interested in results from BT Speedtester.
After all that, get a fault in the queue by visiting http://faults.plus.net
20-07-2010 2:03 PM
I have a ticket in progress but thought I'd also post on the forum as other people may experience the same as me and be helped by the solution I (hopefully find)
Line test 1 tues 20th july 13.53
Download speedachieved during the test was - 6728 Kbps
For your connection, the acceptable range of speedsis 2000-21000 Kbps.
Additional Information:
Your DSL Connection Rate :22221 Kbps(DOWN-STREAM), 444 Kbps(UP-STREAM)
IP Profile for your line is - 19000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 18.56:23.71:57.73 (SBE:NBE:PBE)
20-07-2010 2:08 PM
Quote from: jelv I'm suspecting that you may be suffering from exchange contention. As the exchange checker is not being updated at the moment it's rather difficult to check that out.
8). Have you checked that your exchange is not currently over-subscribed? - http://usertools.plus.net/exchanges/
VP capacity at this exchange is currently showing as Green.
BT have advised that this exchange is enabled for WBC on 21CN
You can view recent Service Outages for this exchange here
BT has published DSL Max upgrade information for this exchange
is this what your refering to Jelv? results are good yes?
20-07-2010 2:48 PM
20-07-2010 4:16 PM
frostwire bittorrent is hardly used and is disabled from auto startup, seriously must use it once a month if that
my bulk downloads come from rapidshare and megaupload and are 90% movies to watch online
20-07-2010 4:43 PM
Quote from: BenTrimble Hi and welcome to the Forums
Speed used to be awesome after 12am on the dot, I was getting 1.8 MB/s I think I've seen it at 2.6MB/s too but of late the after 12am rule has been inconsistent too but averaging on the negative side
Quote Are the speeds consistent across other speed checkers? I'm particularly interested in results from BT Speedtester.
will be doing bt speedtester tests throughout the day evening and tomorrow morning will submit to faults and here too
jim:green quotes fixed mod:end
20-07-2010 4:44 PM
20-07-2010 7:28 PM
Download speedachieved during the test was - 1664 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 21.45:32.33:46.21 (SBE:NBE:PBE)
21-07-2010 2:40 AM
Download speedachieved during the test was - 15940 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 8.86:17.9:73.24 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
21-07-2010 2:49 AM
Line test 2 tues 20th july 19.25
Line test 3 weds 21st july 02.29
21-07-2010 9:38 AM
25-07-2010 8:26 PM
26-07-2010 9:45 AM
