is my pro package all it should be??
jammer2nd
Hey all my 1st post here
I've recently upgraded to the pro package my expected line speed is 13mb but i must admit to not knowing how to read these kb, kB/s
after 12am i usually get a great speed but feel I'm being speed shaped during the daytime and evening which is what i upgraded to pro to avoid
I like coming in in the evening and watching a film online but recently have been getting some lousy results and hoped you experts could make sense of these various readings from mybroadbandspeed and explain to me weather I'm getting normal results (for PN) or something is way out of wack Crazy
i will provide any other info ness on request
get this speed alot between 5pm and 11pm  Cry
one of the faster speeds I achieve Cheesy
16 REPLIES 16
jelv
Fixes: 10
Re: is my pro package all it should be??
I'm suspecting that you may be suffering from exchange contention. As the exchange checker is not being updated at the moment it's rather difficult to check that out. Sad
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
BenTrimble
Hi and welcome to the Forums Cheesy
Do you find that the speeds jump up at a particular time, or is it a more gradual increase?
You're definitely being profiled correctly on our network and speedtest traffic should be prioritised highly regardless of your package.
Are the speeds consistent across other speed checkers? I'm particularly interested in results from BT Speedtester.
After all that, get a fault in the queue by visiting http://faults.plus.net
jammer2nd
Thank you both for your answers
I have a ticket in progress but thought I'd also post on the forum as other people may experience the same as me and be helped by the solution I (hopefully find)
Line test 1   tues 20th july 13.53
Download speedachieved during the test was - 6728 Kbps
For your connection, the acceptable range of speedsis 2000-21000 Kbps.
Additional Information:
Your DSL Connection Rate :22221 Kbps(DOWN-STREAM), 444 Kbps(UP-STREAM)
IP Profile for your line is - 19000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 18.56:23.71:57.73 (SBE:NBE:PBE)
jammer2nd
Quote from: jelv
8). Have you checked that your exchange is not currently over-subscribed? - http://usertools.plus.net/exchanges/
VP capacity at this exchange is currently showing as Green.
BT have advised that this exchange is enabled for WBC on 21CN
You can view recent Service Outages for this exchange here
BT has published DSL Max upgrade information for this exchange
is this what your refering to Jelv?  results are good yes?Huh
BenTrimble
I've just noticed that your upload speed is also slow, suggesting there's something on your computer using your bandwidth. Have you done a full virus scan? Closed any downloading / Bittorrent traffic?
jammer2nd
Hi Ben,  I've been using Mcaffe and spybot for years and on my laptop I use Comodo in stealth mode.  Mcaffe and comodo auto update signatures and I update spybot at least twice a month or if I suspect foul play
frostwire bittorrent is hardly used and is disabled from auto startup, seriously must use it once a month if that
my bulk downloads come from rapidshare and megaupload and are 90% movies to watch online
jammer2nd
Quote from: BenTrimble
Speed used to be awesome after 12am on the dot, I was getting 1.8 MB/s I think I've seen it at 2.6MB/s too but of late the after 12am rule has been inconsistent too but averaging on the negative side
will be doing bt speedtester tests throughout the day evening and tomorrow morning will submit to faults and here too
jim:green quotes fixed mod:end
BenTrimble
Thanks for that. Can you also try running some speedtests with McAfe and Spybot disabled please?
jammer2nd
Line test 2    tues 20th july 19.25
Download speedachieved during the test was - 1664 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 21.45:32.33:46.21 (SBE:NBE:PBE)
jammer2nd
Line test 3    weds 21st july 02.29
Download speedachieved during the test was - 15940 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 8.86:17.9:73.24 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
jammer2nd
ok all 3 test results in one post
BenTrimble
Looks like pretty bad contention Sad faults.plus.net please.
jammer2nd
awaiting faults to get back to me
BenTrimble
Please hold off updating the ticket as this pushed it to the back of the queue. Someone from the Faults Team will be in touch in due course.
