bye bye plus.net
- Feedback
- Plusnet Feedback
- Re: bye bye plus.net
28-01-2010 1:29 PM
And trying to update / configure his new computer has been fun, Not!
@Matt - Thanks for all your efforts, pity the BT "Engineers" aren't as diligent or even trained properly!
28-01-2010 4:26 PM
28-01-2010 6:20 PM
DSL Connection
Link Information
Uptime: 0 days, 9:18:09
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,248
Output Power (Up/Down) [dBm]: 12.0 / 16.0
Line Attenuation (Up/Down) [dB]: 31.5 / 63.5
SN Margin (Up/Down) [dB]: 17.0 / 7.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Framing (Local/Remote): 11 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 17 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 38 / 2,587
HEC Errors (Up/Down): 16 / 1,448
Download speed achieved during the test was - 651 Kbps
Acceptable range of speeds is 200-1000 Kbps.
DSL Connection Rate :1248 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 1000 Kbps
PN IP Profile 1000Kbps
My Broadband Speed Checker Date Download Speed Upload Speed
28 Jan 10 18:09 693 kbps (86.6kB/s) 316 kbps (39.5kB/s)
Braodband Speed Checker Download 680Kbps Upload 332Kbps
Speedtest.net Download 0.69Mbps Upload 0.35Mbps Ping 57ms
29-01-2010 7:56 AM
Post BT REIN "Engineer" visit 29 Jan 2010 @ 07:31 (after re-sync)
DSL Connection
Link Information
Uptime: 0 days, 0:01:31
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,184
SN Margin (Up/Down) [dB]: 16.0 / 7.5
CRC Errors (Up/Down): 0 / 2
HEC Errors (Up/Down): 0 / 2
Download speed achieved during the test was - 857 Kbps
DSL Connection Rate :1184 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
29 Jan 10 07:37 925 kbps (116kB/s) 356 kbps (44.5kB/s)
Broadband Speed Checker Download 912Kbps Upload 332Kbps
Speedtest.net Download 0.93Mbps Upload 0.35Mbps Ping 57ms
Still worried about the errors ramping up at quite a rate and will monitor. Thanks for your assistance in returning to a usable BB service.
29-01-2010 9:29 AM
I've just tested the line and in the 2 hours it's been up there have been 40 errored seconds which isn't too bad - especially given that interleaving is currently turned off. If you're worried then I can put that on, which should pretty much get rid of those - just let me know.
I'm certainly glad that things are now sorted for you, I'll investigate that refund now.
Cheers,
Matt
29-01-2010 11:05 AM
By how much will it affect 'ping' times? or won't we know till we try it?
If it is turned on and games start to experience lag, can it easily be turned off again? (I have a teenager who will not be impressed if his multiplayer games are greatly affected!)
29-01-2010 11:23 AM
Having said that if the errors aren't too bad at the moment why not leave it off until you think it's needed?
29-01-2010 2:14 PM
29-01-2010 2:40 PM
30-01-2010 9:54 AM
DSL Connection
Link Information
Speedtest.net Ping 57ms Download 0.93Mbps Upload 0.35Mbps
29 Jan 2010 @ 17:20
DSL Connection
Link Information
Uptime: 0 days, 9:28:08
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,216
SN Margin (Up/Down) [dB]: 17.0 / 7.5
Error Seconds (Local/Remote): 21 / 0
CRC Errors (Up/Down): 2 / 1,657
HEC Errors (Up/Down): 0 / 707
Download speed achieved during the test was - 862 Kbps
DSL Connection Rate :1216 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
29 Jan 10 17:24 919 kbps (115kB/s) 330 kbps (41.3kB/s)
Broadband Speed Checker Download 912Kbps Upload 342Kbps
Speedtest.net Ping 57ms Download 0.91Mbps Upload 0.36Mbps
29 Jan 2010 @ 22:07
DSL Connection
Link Information
Uptime: 0 days, 14:11:58
Error Seconds (Local/Remote): 22 / 0
CRC Errors (Up/Down): 16 / 2,879
HEC Errors (Up/Down): 2 / 1,283
Download speed achieved during the test was - 869 Kbps
29 Jan 10 22:14 925 kbps (116kB/s) 368 kbps (46kB/s)
30 Jan 2010 @ 09:38
DSL Connection
Link Information
Uptime: 1 day, 1:43:25
Error Seconds (Local/Remote): 39 / 0
CRC Errors (Up/Down): 17 / 4,703
HEC Errors (Up/Down): 3 / 2,173
Download speed achieved during the test was - 871 Kbps
30 Jan 10 09:40 923 kbps (115kB/s) 322 kbps (40.3kB/s)
Broadband Speed Checker Download 920Kbps Upload 312Kbps
Speedtest.net Ping 57ms Download 0.92Mbps Upload 0.29Mbps
Thanks again for your perseverance and forbearance during this rather drawn out affair.
Pete Allison
01-02-2010 8:48 AM
I'm glad everything's holding up well - I don't think those errors are too bad though if they do start to affect the connection let us know and we'll get some testing done.
02-02-2010 5:57 PM
Connection holding, but speed dropping dramatically:
31 Jan 2010 @ 23:13 after connection restored:
DSL Connection
Link Information
Uptime: 0 days, 21:53:08
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,120
SN Margin (Up/Down) [dB]: 17.0 / 8.0
Error Seconds (Local/Remote): 54 / 0
CRC Errors (Up/Down): 12 / 5,612
HEC Errors (Up/Down): 6 / 2,514
Download speed achieved during the test was - 816 Kbps
DSL Connection Rate :1120 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
31 Jan 10 23:15 925 kbps (116kB/s) 359 kbps (44.9kB/s)
Broadband Speed Checker Download 904Kbps Upload 332Kbps
Speedtest.net Ping 57ms Download 0.92Mbps Upload 0.37Mbps
and then tonight (I have also tried at various times during the past couple of days with same speed drops):
02 Feb 2010 @ 17:42
DSL Connection
Link Information
Uptime: 1 day, 8:29:42
Error Seconds (Local/Remote): 219 / 0
CRC Errors (Up/Down): 47 / 13,795
HEC Errors (Up/Down): 12 / 6,934
Download speed achieved during the test was - 679 Kbps
IP Profile for your line is - 750 Kbps
02 Feb 10 17:46 626 kbps (90.8kB/s) 354 kbps (44.3kB/s)
Broadband Speed Checker Download 712Kbps Upload 279Kbps
Speedtest.net Ping 57ms Download 0.75Mbps Upload 0.32Mbps
What can be causing this and why is my BT profile now at 750Kbps?
02-02-2010 6:04 PM
02-02-2010 6:15 PM
02-02-2010 6:18 PM
