bye bye plus.net
- Feedback
- Plusnet Feedback
- Re: bye bye plus.net
26-01-2010 11:25 AM
Quote from: DawnRider @Strat - You just used the words "BT Engineer" and trained in the same sentence! Not in my experience! ![]()
I could have used the word 'experienced' but thought that was pushing it a bit far
26-01-2010 1:55 PM
@Strat, it has certainly been experience watching them running around scratching thier heads muttering "I don't normally do broadband etc etc"
To paraphrase - "Never in the field of human communication has so much misguided effort resulted in such a cluster (muddle)!"
26-01-2010 3:52 PM
26-01-2010 4:01 PM
I know i have requested a mac but i am not going to be using it yet. i know that i have 30 days to use it before i have to request a other one
If the problem is fixed soon then i be more then happy to stay with plus.net
All that i wont is a working stable, stable internet with the full speed i sould be able to get and thats upto 4.5mb but for some reason my line profile as been limited to 1mb for some reason
where i sould be able to get upto 4.5mb as the line check said when i signed upto BT and Plus.net
I will post you a update on both the forums and support ticket.
26-01-2010 4:30 PM
27-01-2010 10:26 AM
Any update refeence the REIN Engineer's visit?
Stats still giving me 448 / 160 up / down at router.
27-01-2010 10:48 AM
Unfortunately no, no change from the message I left for you last night though we are chasing. I'll let you know as soon as we get an update.
I'm wondering if during any of the engineer visits an SSFP (filter faceplate for the master socket) and RF3 filter were fitted at all?
27-01-2010 11:09 AM
On the first visit this and the face plate were removed and a different faceplate fitted.
The second "Engineer" who visited changed this new faceplate for one with built in filters and removed my filter.
The current faceplate is one with both the phone and router connections on the faceplate itself.
All the bits are still on my window ledge. I am having a car boot for BT bits when you have restored my connection speed!
27-01-2010 11:11 AM
27-01-2010 5:22 PM
As per the ticket update/voicemail I've left for you the REIN engineer did attend and find a faulty router in the area interfering with the service on a number of lines. Hope it's made a difference, please let us know if there's been any change and we'll take the according action.
27-01-2010 5:37 PM
28-01-2010 6:52 AM
re-synced and got the following results:
Post BT REIN "Engineer" visit 27 Jan 2010 @ 22:32 (before re-sync)
DSL Connection
Link Information
Uptime: 3 days, 5:21:20
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 160
Output Power (Up/Down) [dBm]: 12.0 / 12.0
Line Attenuation (Up/Down) [dB]: 31.5 / 63.5
SN Margin (Up/Down) [dB]: 11.0 / 8.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Framing (Local/Remote): 11,164 / 0
Loss of Signal (Local/Remote): 1,145 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 31,351 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 75 / 222,349
HEC Errors (Up/Down): 16 / 32,324
Download speed achieved during the test was - 108 Kbps
Acceptable range of speeds is 50-250 Kbps.
DSL Connection Rate :160 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 135 Kbps
PN IP Profile 750Kbps
Post BT REIN "Engineer" visit 28 Jan 2010 @ 06:30 (after re-sync)
DSL Connection
Link Information
Uptime: 0 days, 0:02:03
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,216
Output Power (Up/Down) [dBm]: 12.0 / 16.0
SN Margin (Up/Down) [dB]: 17.0 / 7.5
CRC Errors (Up/Down): 0 / 11
HEC Errors (Up/Down): 0 / 5
Download speed achieved during the test was - 116 Kbps
DSL Connection Rate :1216 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
My Broadband Speed Checker
Date Download Speed Upload Speed
28 Jan 10 06.36 129 kbps (16.1kB/s) 378 kbps (47.3kB/s)
27 Jan 10 21:03 130 kbps (16.3kB/s) 362 kbps (45.3kB/s)
How long before BT raise the profile (and then PN of course)?
28-01-2010 11:33 AM
I'll keep an eye on the connection throughout the day and let you know if I see any drops. Things are looking very positive following the REIN engineer visit.
EDIT: Added a 0. Thanks Jelv.
28-01-2010 11:55 AM
Quote from: Matt I've good news there - the line profile was upped this morning to 100
I'm not sure I'd call 100 good news!
28-01-2010 12:44 PM
