Wrong Link To Findout Which Gateway Your on.
rgt247
Hi
The link on this page is wrong.
http://www.plus.net/support/service/network_performance/broadband_bandwidth_usage.shtml#customerNumb...
The link to check the gateway sends you to "http://usertools.$[http]/@gateway/ " which of course is rubbish.
The correct one is http://usertools.plus.net/@gateway/
Can this fixed asap as it has been wrong for a while.
Rich
8 REPLIES 8
Pettitto
Fixes: 5
Re: Wrong Link To Findout Which Gateway Your on.
Thanks for highlighting Rich.
I've raised Problem 80235 for this to be investigated.
rgt247
Thanks Chris !  Smiley
TORPC
Well spotted Rich Wink
TORPC
Instead of replacing the incorrect link with the correct link they have lost contact with the server, as a server not found is now showing
Chris
Legend
Fixes: 169
It's not pulling the correct URL in there.
If you look at where it's sending you, it's showing as usertools.$[http]/@gateway - the $[http] is the variable for the ISP.
TORPC
Ah!!!!
That explains it then Wink
rgt247
Pleased to see this is now working again.
Thanks for the fix. Smiley
Pettitto
Fixes: 5
Yep that was fixed in the recent release,  glad it's all sorted now Smiley
