Wrong Link To Findout Which Gateway Your on.
- Feedback
- Plusnet Feedback
- Re: Wrong Link To Findout Which Gateway Your on.
28-03-2014 5:13 PM
Hi
The link on this page is wrong.
http://www.plus.net/support/service/network_performance/broadband_bandwidth_usage.shtml#customerNumb...
The link to check the gateway sends you to "http://usertools.$[http]/@gateway/ " which of course is rubbish.
The correct one is http://usertools.plus.net/@gateway/
Can this fixed asap as it has been wrong for a while.
Rich
Rich
8 REPLIES 8
28-03-2014 5:22 PM
Thanks for highlighting Rich.
I've raised Problem 80235 for this to be investigated.
28-03-2014 5:25 PM
Thanks Chris !
![Smiley Smiley](/html/@104CD63F9302A50EF5EC70FE32BB8AA1/images/emoticons/smiley.gif)
28-03-2014 6:48 PM
Well spotted Rich
![Wink Wink](/html/@0FA1396AC0773F33E2DC472BB4F75D3C/images/emoticons/wink.gif)
04-04-2014 12:38 PM
04-04-2014 12:44 PM
It's not pulling the correct URL in there.
If you look at where it's sending you, it's showing as usertools.$[http]/@gateway - the $[http] is the variable for the ISP.
04-04-2014 12:57 PM
Ah!!!!
That explains it then
01-05-2014 10:30 PM
Pleased to see this is now working again.
Thanks for the fix.
Thanks for the fix.
02-05-2014 12:51 AM
Yep that was fixed in the recent release, glad it's all sorted now
- Feedback
- Plusnet Feedback
