Why has my speed been throttled - AGAIN
Oldjim
Resting Legend
Fixes: 63
This month you've used 10.04GB of your 10GB allowance
At the moment your account allows for 10GB of peak-time usage per month.
You've probably noticed that your broadband speeds are slower than usual,
this is because you've gone over your monthly usage allowance.  Don't
worry, your speed will be back to normal at the end of your billing month.
If you'd like to return to full speed now, you'll need to increase your
usage allowance.
There are two ways to do this, you can either:
- Increase your usage allowance - (75p per GB added)
- Use what you like now and pay for it at the end of the month - (£1.00
per GB used)
Choose what works for you at the following link:
- https://portal.plus.net/my.html?action=control_your_broadband
If you'd like to find out more about traffic management and usage
allowance there's a load of information on our website:
- https://www.plus.net/support/broadband/products/broadband_your_way/
To see a breakdown of your usage this month go to the following link:
- http://portal.plus.net/view_my_broadband_usage/
Thanks,
Plusnet Customer Support
See attached picture - I added the extra £5 about a week ago
25 REPLIES 25
jelv
Fixes: 10
Re: Why has my speed been throttled - AGAIN
- Use what you like now and pay for it at the end of the month - (£1.00 per GB used)
Which account type are you on?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Oldjim
Resting Legend
Fixes: 63
The one where I add £5 per 5GB - see picture
andre88uk
I would add £100 limit then when they bill you send them the email.and say you will pay 75.p per gb
jelv
Fixes: 10
So not only have they restricted your account, they've also sent you a BBYW email instead of the Value email.
Not doing too well are they! Sad
orbrey
Hi Jim,
Now raised under problem 69868, we'll advise as soon as we can. Sorry about this.
Kelly
Fixes: 9
Quote from: jelv
Embarrassed
Kelly Dorset
Ex-Broadband Service Manager
Oldjim
Resting Legend
Fixes: 63
How about manually lifting the restriction in the meantime  Sad
Chris
Legend
Fixes: 169
In progress Jim.
I'll drop a ticket on your account as I've just made a change to the additional usage to try and sort that out too.
Oldjim
Resting Legend
Fixes: 63
Thanks Chris - new speed test
Oldjim
Resting Legend
Fixes: 63
To assist in problem solving - this is when it happened last time
http://community.plus.net/forum/index.php/topic,95129
and to this user
http://community.plus.net/forum/index.php/topic,95292.0.html
Previous problem ID 66699
adamwalker
Fixes: 221
Thanks Jim
 Adam Walker
If a user does get their speed throttled, is this 24 hours a day, or is the overnight unlimited period unthrottled ?
Oldjim
Resting Legend
Fixes: 63
24 hours per day
Oldjim
Resting Legend
Fixes: 63
Now waiting for another email to see if it is correct
