Why has my speed been throttled - AGAIN
- Feedback
- Plusnet Feedback
- Why has my speed been throttled - AGAIN
- « Previous
- 1
- 2
- Next »
Re: Why has my speed been throttled - AGAIN
21-02-2012 11:56 AM
What email are you expecting?
Jojo
21-02-2012 11:59 AM
The one about approaching my usage allowance was correct
21-02-2012 12:06 PM
21-02-2012 12:46 PM
Quote You've now reached the extra usage limit you set for your broadband service. Your broadband service will be restricted until the end of your billing month.
Your extra usage price limit is currently set to £0.
For more information on the level of service you can expect - http://www.plus.net/support/broadband/quality_broadband/speed.shtml
Increase your Usage Limit
You can increase your usage limit if you want more usage - https://portal.plus.net/data_transfer_watch/
View Your Broadband Usage
You can check your usage at any time on our website with View Your Broadband Usage - https://portal.plus.net/view_my_broadband_usage/index.php
21-02-2012 12:55 PM
17-03-2012 1:11 PM
Quote Dear <snip>,
Account username: <snip>
At the moment your account allows for 10GB of peak-time usage per month.
You've probably noticed that your broadband speeds are slower than usual, this is because you've gone over your monthly usage allowance. Don't worry, your speed will be back to normal at the end of your billing month.
If you'd like to return to full speed now, you'll need to increase your usage allowance.
There are two ways to do this, you can either:
- Increase your usage allowance - (75p per GB added)
- Use what you like now and pay for it at the end of the month - (£1.00
per GB used)
Update - nearly 4 hours now and still throttled
19-03-2012 8:44 AM
19-03-2012 1:50 PM
19-03-2012 5:07 PM
The problem appears to be that part of the Ellacoya system thinks I am still on BBYW Option 2 and up to now they have been unable to fix it
This is the last time I will post in this thread until they sort the problem or I reach my billing date on Friday morning which will reset it anyway
19-03-2012 5:52 PM
20-03-2012 2:34 PM
They are going to try Jelv's suggestion
One thing, which I wondered may have contributed to the problem was that I went from BBYW Opt 2 to BBYW Opt 1 10GB special offer to Value and that may have screwed something up.
- « Previous
- 1
- 2
- Next »
