Why don't plusnet launch a new FTTC product
deathtrap
With the complaints  about peak time issues  I was pondering  over solutions and came up with this idea
Plusnet  launch a new but more expensive FTTC 80/20 service aimed at  those who expect their bb to be free from all the peak time issues
in return for a higher monthly fee, we would get better routing /peering  and a priority over other customers so lower contention on your network, throughput speeds would only be restricted by the BTW IP profile (so no plusnet shadow) and no Fiddling with traffic, that's the end users job should they need or want to do this
and finally non of this  porn filtering on by default
4 REPLIES 4
ejs
Aspiring Hero
Fixes: 25
Re: Why don't plusnet launch a new FTTC product
WBC Elevated is an additional £3/month excluding the VAT according to the WBC Price List spreadsheet. It's almost as if there's already something that would give your traffic higher priority over the BTWholesale network. Perhaps you'd want that as part of it.
deathtrap
for the sake of £3 why not, as long as it actually made a difference ,and yes they could already do this, but i think there's more to  having peak times free of issues than adding this £3 option
rongtw
Fixes: 12
would this option help with gaming ? as i get peak time problems,  but still have a decent connection but still find i have to gateway hop to find a gateway the plays ok  Wink
deathtrap
Probably not as it wouldn't affect jitter and latency to specific hosts as it i think just prioritises throughput rates  by a small amount
