Unreliable connection today
- Feedback
- Plusnet Feedback
- Unreliable connection today
28-12-2009 12:08 PM
Am I alone? In other words is it a fault at my end?
I have restarted my router a couple of times and cut off it's power once.
Regards
PS currently both services are working.
Re: Unreliable connection today
28-12-2009 12:12 PM
Glad it's not me!
Regards
28-12-2009 12:13 PM
http://www.plus.net/supportpages.html?a=2&support_action=messages&ispservice_id=services
read the first two messages "together"
I could not connect this morning at 0655, phoned broadband faults, to hear the above message.....
Remember..... do not keep "re-booting". as the equipment will think that you have a line fault, and drop your synch speed...
re-boot once, after switching off for at least 15 minutes..... then do not re-boot again for at least 1 hour.... (if needed.)
You have seen it. as I was typing this ! ! !
28-12-2009 12:28 PM
28-12-2009 7:42 PM
What's the trick to getting a fast sync again? Is it 'the longer you leave it off between connections, the better'? So if I set my router on a timer which turned it off at 6am and on at 7am for the next three days or so - would that convince the software at the other end that the problems are not mine?
28-12-2009 8:01 PM
Quote Data Centre Outage (59918) - NEW
Services
Posted on: Monday 28 December 2009, 06:11
We are currently experiencing a power failure at one of our London Datacentres.
This has caused a number of customers to be disconnected and may also cause problems with email as well as general web browsing.
Our engineers are working to restore service as soon as possible.
Sorry for any problems this is causing you.
Kind Regards,
Quote Data Centre Outage (59918) - UPDATE
Services
Posted on: Monday 28 December 2009, 15:55
Further information has been received advising that the replacement part has now been fitted. Customers should now see improvements in their speeds and the data transfer issue is now resolved.
Our network engineers will continue to monitor our platform before fully closing this issue.
Please accept our apologies for any inconvenience caused during this time.
Kind Regards,
30-12-2009 9:44 AM
What kind of speeds does the BT Speedtester give you now? Your profile is at 6000 so it should be higher than you saw yesterday (although the data centre issues won't have helped).
01-01-2010 5:28 PM
Total frustration when one is in the middle of a job. I have to use the 'restart' facility on the Thomson but download speed is dropping off [that being the original reason for ticket ID: 31200280].
Not a good way to start the New Year!
06-01-2010 10:06 AM
@exporters, looks like things are much better for you now? The fault is with BT still though, so they may be able to improve things further.
06-01-2010 1:00 PM
I would like to emphasise, Mand, that my original observation was purely to determine where the problem lay. I am an extremely satisfied PlusNet user of some 6-years (next month)..... Internet, email, Home Phone, Broadband Phone.....and over the years, following some hiccups in the early days, the service has become consistently superb.
I only wonder why everyone doesn't use PlusNet!
Many thanks for monitoring this matter, Mand.
Noel
PS A good New Year to you all, too!
08-01-2010 12:04 AM
Thank you, I too thought all was starting to look good but fell over yesterday & not helped today with electric power supply off/on. I'll await the verdict of BT as you say; guess it may be a good few days before they get back to normality with this weather.
