Unlimited traffic hitting traffic shaping limits
- Feedback
- Plusnet Feedback
- Unlimited traffic hitting traffic shaping limits
16-01-2014 9:30 PM
Usenet / P2P is as low as 800Kb/sec during peak times - I can do 80Mb/sec off peak hours!
Traffic shaping rules for Unlimited product were quite clear when lauched, all traffic Gold except P2P/Usenet which is Bronze, however Plusnet manage the bandwidth requirements to ensure that bronze traffic is not dropped unless some sort of major incident and therefore should be expected at line speed at all times.
Well there is no major incident this evening - yet 800Kb/sec instead of 80Mb/sec is some serious traffic shaping i.e. PlusNet require a massive purchase of additional bandwidth to stop these traffic limits being hit - which was their promise when they launched the unlimited service wasn't it.
Re: Unlimited traffic hitting traffic shaping limits
16-01-2014 9:44 PM
Ex-Broadband Service Manager
16-01-2014 9:57 PM
16-01-2014 10:00 PM
Quote from: jelv Tam can you run a thinkbroadband speed test please. If that runs full speed it's a traffic management issue. It that is also slowed it could be something else.
TBB taken just now - http://www.thinkbroadband.com/speedtest/results.html?id=13899095349354312941
speed tests taken earlier whilst usenet running at snails pace - see time stamps in images for the times.
http://www.speedtest.net/result/3236684168.png
http://www.speedtest.net/result/3236686685.png
http://www.speedtest.net/result/3236691430.png
http://www.speedtest.net/result/3236838534.png
http://www.speedtest.net/result/3236841131.png
16-01-2014 10:04 PM
16-01-2014 10:06 PM
Sorry
16-01-2014 10:08 PM
Kelly - if he tries it will you credit the cost?
Edit: If it's a profile mismatch might a disconnect/reconnect bring it back in line? Worth a try?
16-01-2014 10:16 PM
16-01-2014 10:20 PM
16-01-2014 10:21 PM
This is the latest one done just after the TBB speed test you requested http://www.tamlync.com/plusnet/speed/pcl-ag06-1.png
Previous history this evening....
PCL-AG08
Speed test = 60/16
TBB 1Gb test file = 8.03MB/s
Usenet = 2.93MB/s
PTN-AG03
Speed test = 53/16
TBB 1Gb test file = 7.22MB/s
Usenet = 1.14MB/s
PTW-AG01
Speed test = 63/18
TBB 1Gb test file = 7.61MB/s
Usenet = 1.78MB/s
PCL-AG04
TBB 1Gb file = 7.54MB/s
Usenet = 1.43MB/s
PCL-AG07
Usenet = 1.41MB/s
I have screenshots of most of the above speeds listed too..
16-01-2014 10:23 PM
It is actioned pretty much straight away.
16-01-2014 10:29 PM
Quote from: jelv Give the pro add on a go: https://portal.plus.net/AddOns.html
done - does the router need a disconnect and reconnect for profile to take affect?
16-01-2014 10:38 PM
16-01-2014 10:54 PM
Quote from: jelv It shouldn't but if you see no difference in say ten minutes give that a try.
Now coming in at 7MB/sec + so all good again - but also - now no longer peak time.... will have to see what tomorrow brings - although if i have pro - i guess that it'll stay full whack anyway..
17-01-2014 5:38 PM
I thought it won't start until your next billing date?
- Feedback
- Plusnet Feedback
