Top Quality work
NickF
Top Quality work
Kelly have been to install a new line on behalf of BT.
Wanted to share with everyone what quality work looks like Grin
18 REPLIES 18
twocvbloke
Re: Top Quality work
Goodness me that's worse than what I'd do (not exactly competent with a drill myself!!), hope they pay for the damages.... Shocked
jafreer
Pretty shocking. At least they didn't drill through the window frame Smiley
davidj66
Fixes: 4
Is that blood on the wall?....from when you bopped him on the nose,I hope? Grin
southerner
Oh my, that's terrible. Looks like a very bad attempt at DIY.
HarryB
Fixes: 256
Hi Nick, I want to raise this with our suppliers to try and get this sorted out as this is quite clearly not to the standard we'd expect.
Would you mind pming me the username of the account it relates to please.
In the meantime, if you want to try and report it directly due to damage to your property you can call Openreach directly on 0800 671130
 Harry Beesley
Alex
Fixes: 13
Even from me, who has no building experience whatsoever, I can see it's bad that they just left a loose cable into the wall.
w23
Fixes: 4
You'd have thought he'd sharpen his hammer before using it to make the hole for the cable.  I bet he used the hammer too for inserting the screws into the wallplugs (if he even used wallplugs).
Call me 'w23'
gleneagles
Aspiring Legend
Fixes: 17
Even worse is the fact that whoever did this probably holds some formal qualifications.
Glad you reported it, be interesting to see his other handywork.
We are born into history and history is born into us.
pvmb
All Star
Fixes: 14
Look on the bright side! At least they provided a rainwater drip loop on entry, I've often seen satellite installers who hadn't even done that. Sad
Who or what are "Kelly"?
Estragon
Kelly's and Quinn's are the two subcontractor telecoms engineer firms Openreach took on when the demand for FTTC installations overwhelmed them quite a long time ago.
The horror stories are legion :(.
NickF
Hi all,
Thanks for all your comments
Hopefully it's getting sorted.
Nick
Gel
Champion
Fixes: 29
MattyC
Fixes: 46
Just a word of warning; that Twitter feed usually directs you our way (though their response may be interesting). Harry's in at 11:30, so if you've sent him a PM, I'll give him a nudge.
Kremmen
Fixes: 5
These pictures are similar to some of the installations Virgin Media sub-contractors have been doing round my way and why I'm not entertaining them for anything, even though they send me a discount pack every month.
If you drill brick from the inside out and use the hammer option all the way through then that outer layer drop off is what happens.
Let's be careful out there !
