This needs correcting
Oldjim
Resting Legend
Fixes: 63
http://www.plus.net/support/broadband/products/IP_addresses_broadband.shtml
3. How to switch between a dynamic & static IP
Plusnet Unlimited / Unlimited Fibre
Go to Add-Ons, which you'll find under Connection Settings in My Account
From here, you can see your current IP address settings. Switch between static and dynamic by clicking the button.
Please note:
    There's a £5 setup fee to activate a Static IP
    You'll need to reboot your router before the change takes effect
    If you remove a Static IP, you're unlikely to get the same address if you switch back in the future
    Add-Ons will not appear for accounts where switching is not available
You do not need to reboot the router - a simple disconnect/reconnect will do it
3 REPLIES 3
shalom2010
Re: This needs correcting
That's what I did Oldjim, but I wanted to point to the help file.
adamwalker
Fixes: 223
Thanks for the suggestion Jim,
This has been discussed quite a bit before. The reason we've mentioned a reboot rather than a soft disconnect/reconnect as advising customers on mass to do that could drive a lot of support requests our way for advice on how to log into the router and do that.
Also we're happy that an occasional/one-off reboot shouldn't have any negative impact.
 Adam Walker
jelv
Fixes: 10
Jim,
It's written that way so when people complain about slow speeds they can fob them off by blaming them for rebooting the router! Tongue
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
