Stuck with this for another year.
- Feedback
- Plusnet Feedback
- Stuck with this for another year.
19-07-2009 5:20 PM
Re: Stuck with this for another year.
19-07-2009 5:37 PM
If you are getting similar results from a Netgear and a Thompson the BT isn't going to be very different (if at all).
Have you tried using different channels?
19-07-2009 5:45 PM
also some of the ideas in this thread may increase your coverage of wireless around your home.http://community.plus.net/forum/index.php/topic,77852.0.html
also remember that on bt's low cost package they now restrict iplayer speeds
19-07-2009 7:19 PM
19-07-2009 8:18 PM
19-07-2009 10:56 PM
Quote which is never situated more than 30 feet away from my own
30 ft is Ok in the open air, even 100 ft, But if you are indoors and you have walls in the way that are more than paper thin,you will be lucky to get a signal off any router
Have you checked if any other person is on the channel that you are using, there are 11 and it is often seen that in a busy area more thaqn one on the same channel.
dont discard the suggstions of the other posters, Cable to cat5 is the best, and homeplugs also work well
19-07-2009 11:15 PM
Router is on a table and has clear view into the hallway - but keep it as high as you can in the room.
20-07-2009 12:42 AM
20-07-2009 10:10 AM
21-07-2009 12:43 PM
21-07-2009 1:08 PM
This thread set me thinking - so I did the tests I describe here:
http://community.plus.net/forum/index.php/topic,77935.0.html
21-07-2009 3:37 PM
Also consider devices that may be between the router and your laptop. Handsfree phones and microwave ovens especially are bad. Anything metal (fridges, bannisters, bedframes) will also interrupt your signal.
21-07-2009 4:41 PM
Maybe he is trying his router in the cave next door?
28-07-2009 1:10 PM
28-07-2009 1:19 PM
It's a Thomson Router, but not a 585. It's one of the ones with two VoIP ports, but I can never remember the model number. I'm also far too lazy to change the wireless channel and so on, I just run a 30 foot CAT5E cable up to my room.
