So far so bad...
- Feedback
- Plusnet Feedback
- So far so bad...
- « Previous
- Next »
Re: So far so bad...
31-12-2010 10:25 AM
hopefully this fix will be for a longer duration this time
31-12-2010 1:22 PM
The agent you spoke with this afternoon has just been over for a chat. The banding hasn't been removed yet, I would expect this within the next hour or so. However this may only take temporary effect as your connection is still intermittent at the moment.
To cut a long story short we've passed the fault report back to BTW to advise of this and we'll get back to you when we have the next response.
31-12-2010 2:03 PM
just done a stats incase it helps anyone..
Link Information
Uptime: 0 days, 13:00:28
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,072 / 6,996
Bandwidth (Up/Down) [kbps/kbps]: 444 / 2,270
Data Transferred (Sent/Received) [MB/MB]: 17.81 / 43.87
Output Power (Up/Down) [dBm]: 12.5 / 20.0
Line Attenuation (Up/Down) [dB]: 25.0 / 44.5
SN Margin (Up/Down) [dB]: 24.0 / 9.0
Loss of Link (Remote): 0
FEC Errors (Up/Down): 31,424 / 196,329
CRC Errors (Up/Down): 1,298 / 4
HEC Errors (Up/Down): 16 / 10
31-12-2010 2:45 PM
31-12-2010 4:00 PM
Uptime: 0 days, 0:46:33
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,068 / 7,004
Bandwidth (Up/Down) [kbps/kbps]: 444 / 2,268
Data Transferred (Sent/Received) [MB/MB]: 1.29 / 2.73
Output Power (Up/Down) [dBm]: 12.5 / 18.0
SN Margin (Up/Down) [dB]: 23.5 / 9.5
Loss of Framing (Local/Remote): 39 / 0
Loss of Signal (Local/Remote): 2 / 0
Error Seconds (Local/Remote): 19 / 0
FEC Errors (Up/Down): 0 / 7,578
CRC Errors (Up/Down): 21 / 0
HEC Errors (Up/Down): 7 / 0
31-12-2010 6:54 PM
DSL Connection
Link Information
Uptime: 0 days, 3:37:42
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,064 / 6,392
Data Transferred (Sent/Received) [MB/MB]: 10.37 / 51.26
SN Margin (Up/Down) [dB]: 23.0 / 7.5
FEC Errors (Up/Down): 0 / 35,140
31-12-2010 8:05 PM
Physical Connectivity OK
DSL Connection
Link Information
Uptime: 0 days, 4:50:52
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,072 / 6,380
Data Transferred (Sent/Received) [MB/MB]: 12.69 / 70.47
SN Margin (Up/Down) [dB]: 23.5 / 7.5
FEC Errors (Up/Down): 0 / 80,280
01-01-2011 2:40 PM
DSL Connection
Link Information
Uptime: 0 days, 0:50:15
Maximum Bandwidth (Up/Down) [kbps/kbps]: 888 / 6,936
Bandwidth (Up/Down) [kbps/kbps]: 440 / 6,136
Data Transferred (Sent/Received) [MB/MB]: 3.21 / 10.36
Output Power (Up/Down) [dBm]: 12.0 / 20.0
SN Margin (Up/Down) [dB]: 24.0 / 7.5
Loss of Signal (Local/Remote): 65,538 / 0
Error Seconds (Local/Remote): 65,538 / 0
FEC Errors (Up/Down): 0 / 56,663
CRC Errors (Up/Down): 0 / 47
HEC Errors (Up/Down): 0 / 388
01-01-2011 7:10 PM
DSL Connection
Link Information
Uptime: 0 days, 5:22:55
Maximum Bandwidth (Up/Down) [kbps/kbps]: 888 / 6,784
Data Transferred (Sent/Received) [MB/MB]: 8.51 / 33.28
SN Margin (Up/Down) [dB]: 24.0 / 7.0
Error Seconds (Local/Remote): 131,098 / 0
FEC Errors (Up/Down): 32,608 / 751,083
CRC Errors (Up/Down): 0 / 1,447
HEC Errors (Up/Down): 0 / 21,523
02-01-2011 2:48 PM
Download speedachieved during the test was - 3613 Kbps
For your connection, the acceptable range of speedsis 2000-7150 Kbps.
IP Profile for your line is - 5000 Kbps
02-01-2011 5:59 PM
Uptime: 0 days, 2:58:24
Maximum Bandwidth (Up/Down) [kbps/kbps]: 888 / 6,820
Bandwidth (Up/Down) [kbps/kbps]: 440 / 6,456
Data Transferred (Sent/Received) [MB/MB]: 17.87 / 319.58
SN Margin (Up/Down) [dB]: 24.0 / 6.0
Error Seconds (Local/Remote): 32 / 0
FEC Errors (Up/Down): 36,032 / 1,450,471
CRC Errors (Up/Down): 1,281 / 1,776
HEC Errors (Up/Down): 7 / 70,221
02-01-2011 9:26 PM
Download speedachieved during the test was - 4739 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 16.72:20.04:63.24 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
DSL Connection
Link Information
Uptime: 0 days, 6:26:07
Maximum Bandwidth (Up/Down) [kbps/kbps]: 888 / 6,408
Data Transferred (Sent/Received) [MB/MB]: 34.33 / 395.22
SN Margin (Up/Down) [dB]: 24.0 / 4.5
Error Seconds (Local/Remote): 82 / 0
FEC Errors (Up/Down): 36,032 / 3,176,661
CRC Errors (Up/Down): 1,281 / 4,408
HEC Errors (Up/Down): 208,011,264 / 201,132
05-01-2011 4:12 PM
but have a shedload of errors now...
(Local/Remote): 70,218 / 0
FEC Errors (Up/Down): 72,064 / 95,264,278
CRC Errors (Up/Down): 2,562 / 178,833
HEC Errors (Up/Down): NA / 1,030,290
presubable NA is too emarrasing to show..
still waiting on the new equipment arrriving... but atleast we seem to have stabalised the line..
- « Previous
- Next »
