Slow replies to open questions,
Oldjim
Resting Legend
Fixes: 63
Re: Slow replies to open questions,
I hoard things like that just in case (including pci network cards, modem cards, wireless cards, etc.)  Grin
jojopillo
Dan,
I've popped a router in the post and it has 2 filters with it.
Jojo Smiley
chandu
Quote from: Oldjim
From very limited experience - my connection - my default noise margin jumped up 6dB on changing from 20CN to 21CN for no apparent reason.
Yours appears to have increased either to 9dB or 12dB given the reported noise margin of 10.9dB
I would suggest asking for a reset or retrain - not sure which is available now
What's this do with the OP thread?
chandu
Quote from: chandu
Sorry, Oldjim.  Please disregard the comment.  My sincere applogies.
Jo,
Thank you for supplying another router.
As requested I have moved the router to the test socket.
Router in study
System Up Time 358:53:36
ADSL Link Downstream Upstream
Connection Speed 2656 kbps 448 kbps
Line Attenuation 55.0 db 28.0 db
Noise Margin 10.2 db 21.0 db
Router connected at test socket
System Up Time 00:06:46
Connection Speed 2560 kbps 448 kbps
Line Attenuation 54.0 db 28.0 db
Noise Margin 12.0 db 21.0 db
I have had to use a RJ11 to RJ11 cable from Filter to Modem, where as before I was using a RJ11 to BT Plug cable. (No phone connected in study)
I have updated question 49441430. Any thoughts?
Dan
jojopillo
Dan,
What I want to do is get the router I sent you into the test socket with an inline filter and reset your SNR. this should give us the best performace and we can see how stable it remains.
Jojo Smiley
JoJo,
I'll let you know when I have fitted the new router. How shall I update you, here, PM or via the open question?
Dan
orbrey
Hi Dan,
Updating both the ticket and this thread would be best I think, I wouldn't send a PM. Jojo (or one of us) will pick it up from here when you let us know Smiley
The new router is now in place.
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 2,464
Output Power (Up/Down) [dBm]: 11.5 / 17.5
Line Attenuation (Up/Down) [dB]: 28.0 / 52.0
SN Margin (Up/Down) [dB]: 21.0 / 12.0
Unfortunatly looks much the same as the netgear router.
Dan.
jojopillo
Hi Dan,
now you've got the new router in the test socket I'll reset the SNR and see how we go.
Jojo Smiley
Update:-
Uptime: 1 day, 2:44:36
Bandwidth (Up/Down) [kbps/kbps]: 448 / 2,784
Output Power (Up/Down) [dBm]: 11.5 / 18.0
SN Margin (Up/Down) [dB]: 21.0 / 9.5
This might be the best we get!
Thanks for your help so far.
Dan.
Back where we started:-
Uptime: 0 days, 17:05:00
Bandwidth (Up/Down) [kbps/kbps]: 448 / 2,368
SN Margin (Up/Down) [dB]: 21.0 / 11.0
I have noticed since using this device I get more disconnects. Is this it then, do I have to accept a slow connection? Can we not use ADSL2+ and go back to ADSL1?
Edit:-
Been doing some research it would appear I am already ADSL1; router reports DSL Type: G.992.1 annex A. Is this the best I can expect from now on, as I've said before I have had much faster connections than this.
The router is very slow to respond whe I click on options, is this normal?
Dan.
jojopillo
Hi Dan,
I can place an order to put you onto ADSL1 on 21CN. Once on there we should be able to tweak things a bit easier for you. It doesn't look like the SNR reset worked the other day. Are you happy for me to go ahead?
Jojo Smiley
JoJo,
If it will improve stablity and profile speed then yes please proceed.
Many thanks
Dan.
jojopillo
Hi Dan,
I couldn't tell you what difference it will make, but if it was me, I'd do it.
Jojo Smiley
