Router hasn't arrived
- Feedback
- Plusnet Feedback
- Router hasn't arrived
27-10-2015 3:04 PM
Thanks,
Peter
Re: Router hasn't arrived
27-10-2015 3:22 PM
27-10-2015 3:52 PM
Thanks for the quick response,
Peter
27-10-2015 4:01 PM
they simply ensure there is a connection at the OR modem.
27-10-2015 4:35 PM
Chenks76, my friends have had the router set up for them by the BT engineer. When I agreed my fibre deal with Plusnet I was told "it would be up and running at 40GB when the engineer left".
27-10-2015 5:32 PM
the openreach engineer installed the OR modem and completes the line tests using that, the router is not required to do that.
also, if they said you have be "running at 40GB" then they misled you.
they have no way of telling what speed you will actually get until the install has been completed.
28-10-2015 2:28 PM
Quote from: chenks76 Also, if they said you have be "running at 40GB" then they misled you.
Now that's interesting. When told it would be an 18-month contract for unlimited fibre and 40GB connection I asked the Plusnet employee what happens if I don't get the promised 40GB. He specifically stated that 40GB was guaranteed, plus or minus 1GB. I assumed that he was telling the truth because when I entered my post code and phone number on the BT checker it said something like 68GB would be potentially available.
Are Plusnet staff telling lies to get orders?
28-10-2015 2:45 PM
it's an "up to" 40Mbps connection.
any speed "promise" given out before the installation has actually taken place is simply a educated guess based on what openreach think you may get.
chances are you may get extremely close to 40Mbps, but it's impossible to tell until the installation has taken place.
if they actually used the word "guaranteed" (which i doubt) then they have made a mistake.
also the "plus or minus 1GB" (again i will assume a typo). it's impossible for it to be plus 1Mbps as they profile is capped at a max of 40Mbps. it can never be 41Mbps.
also, it's advertised as "up to" 38Mbps anyway, never 40.
28-10-2015 3:10 PM
28-10-2015 3:50 PM
tijara33, thanks for your comment. I don't have much to upload so that shouldn't be a problem.
28-10-2015 4:18 PM
there is no 10 day training for FTTC (that's just for ADSL).
28-10-2015 4:59 PM
About time PN Trained their Staff not to say this
29-10-2015 10:14 AM
