Reset profile please
glloyd
Can some kinds c/s person reset my profile to 15.07, it's been wrong for a week or so now. Thank you.
3 REPLIES 3
Fixes: 251
Re: Reset profile please
Hi George,
"Wrong" from what perspective?  Against your current synch rate or wrong against what BT is reporting or wrong against what it has been / you believe it should be?
The figure you quote is a BT Profile figure.  PlusNet figures are rounded down to 0.10Mbps so it is equivalent would be 15.0Mbps, requiring a synch speed of 18.086Mbps
PlusNet has no control over BT Profile figures.
Kevin
MatthewWheeler
Fixes: 503
Hi there.
I've updated your profile to match the BT one.
If you log into your router and disconnect then reconnect you should see a increase.
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
glloyd
Thank you.
